I am new in this, and I am doing a swap on a 1988 Camaro with an engine of a 1998 K2500 350ci engine, my idea is do the nexts things:
? Disable the VATS (The most easy).
? Disable the oxygen sensor bank n? 2 complete and one of the bank n? 1 (It?s only posible to disable on DTCs errors or can be disable in other site? The combustion will be the right?).
? Configure for mechanic or manual transmission (I must do something with the other configures of the gears and others?).
? Disable VSS (It?s posible? I have no sensor).
? Disable EGR (It?s only posible to disable on DTCs errors or can be disable in other site? The valve won?t be there).
Thank you so much.
Best regards,
