Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 82
Thread: Configuration & Histogram Repository
  1. #41
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,288
    Quote Originally Posted by Justinmofo View Post
    Does anyone have histograms for BETA scanner? None of mine will work now that I have beta.
    Nothing has changed in this regard. Any histograms created with 2.22 WILL work with 2.23 so long as you are logging the correct pids. If you aren't logging the correct pids then thats a whole different issue that only YOU can correct.
  2. #42
    Mar 2006
    11
    Bill,
    I am having the same issue, I'm running beta version 2.23.3468.18986 and when I open a config file it says "Histogram Display Failed to Load. This file was created with a newer version of the software. Please update your software to the latest version!"
    Should I download version 2.22 or is their a newer beta that will fix this?
    Ben
    2002 Formula
    700rwhp
    2008 G8 GT
  3. #43
    Aug 2011
    16
    I made a quick LTFT MAF edit table. I suppose this could also be used for STFTs too. I have not used it yet but once I do I will be sure to post results. Simply plug in current MAF table, then logged MAF vs Hz fuel trims from your histogram and then copy new tables into your BIN. Hopefully this helps some people out and that this is the right place for this.
    EDIT: Made a mistake in my math. This one is good. Tried it out and works great! Have fun!
  4. #44
    Advanced Tuner domestic rice's Avatar
    Dec 2006
    MB SC
    494
    The configs make my head hurt..... anyone have a general config that will actually let me log everything for I know its better to have several small ones to get better resultion, but I cant get the hang of them and my 99Z does not work on these of course.
    1. 2007 avalanche 5.3
    2. 2009 chevy 2500hd 6.0
    99Z A4 w/ SS LT's, h/f cats, magnaflow catback, port/polish t/b, egr deleted, ls6 intake, lid, 3.73's, hpt, performabuilt level 1 tranny, 3600 stall, Stage 2.5 (5.3 heads), Torquer 2 cam, 42# reworked injectors, TR6 plugs.
    2007 Avalanche LTZ - Catback and Eibach springs
  5. #45
    guys i have 2.23 beta hp tuner
    i don't know where should i add those pids
    could you please guide me?
  6. #46
    Sep 2007
    4
    Realizing this may be a the wrong place to post this.
    Working to tune an 06 Grand Prix GXP 5.3 LS4. Can't get the STFT's to read correctly on the histogram. I've setup hi and lo maf vs STFT histograms, tried using EC's from the beginning of the thread and nothing is making sense.
    For example, watching the STFT on the gauge or table displays, I'm seeing normal STFT's +12 to say -14. Clearly needs a tune. Using the histogram of maf airflow vs output frequency low against the STFT, I'm getting -45 when STFT on displays is -11.
    Doesn't seem logical. Looking at the sensor it's good, histogram appears to be logging something entirely different.
  7. #47
    Mar 2006
    29
    Anyone have a config and Hist for a 01 camaro with maf tuning and egr enabled to my wide band commander. 0-5v
  8. #48
    Tuner in Training Jeffrey110's Avatar
    Jun 2011
    Toledo,Ohio
    28
    Anybody have anything for a 12 camaro 1SS LS3. E38? Looking for a basic config. Narrowband AFR, MAF, Timing, Knock retard, and STFT's + LTFT's . Just wanting to see what the PCM see's for basic street tuning. looking to tune, timing MAF and AFR.
    Thank you in advance.
  9. #49
    Tuner Stuffs's Avatar
    Dec 2013
    Denver
    111
    Quote Originally Posted by flame View Post
    Somebody should clean the crap out of this thread to make it sticky worthy
    this , im looking for a good config for VE in SD , for a 2006 c6 ls2 with a E38...
  10. #50
    Jan 2015
    11
    how do you set up corrected eq ratio? i try to enter into tables and charts and it does not give a reading. it displays nothing while running or cranking. it does not have a unit.
  11. #51
    Advanced Tuner jpb1972's Avatar
    Mar 2015
    New Jersey
    271
    Need to build 2 histograms. (LTFT + STFT vs Maf freq (Hz)) and another for (MAF hz vs AFR error). If anyone has these for 2010 ls3 or can help me out in building them I would GREATLY appreciate it. Help files have not HELPED.
  12. #52
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by jpb1972 View Post
    Ned to build 2 histograms. (LTFT + STFT vs Maf freq (Hz)) and another for (MAF hz vs AFR error). If anyone has these for 2010 ls3 or can help me out in building them I would GREATLY appreciate it. Help files have not HELPED.
    You need to setup two user defined PID's. One will be total fuel trims for bank 1, the other the total for bank 2. Formula for bank 1 that I'm using is [PID.6]+[PID.7]. Bank 2 is [PID.8]+[PID.9]. This is on an E40 so it may differ on yours. Lookup correct PID's for yours. If you don't know how to do this then let me know and I'll try to walk you through it in more detail
    To make the histogram, get to histogram settings and pick whichever one you want to use. I use #6 for bank 1, #7 for bank 2. Bank 1 settings are:
    Set "PID" to the custom PID you setup earlier (i.e. total fuel trims bank 1). Optional: Under filter put in [PID.68]=1. That will make it only log when you aren't in power enrichment mode. Under rol/col axis, clear out whatever is in there if there is anything. For the column sensor, set it to Maf Air Flow Freq, unit = hz, and use these for break points: 1000,1150,1300,1450,1600,1750,1900,2050,2200,2350, 2500,2650,2800,2950,3100,3250,3400,3550,3700,3850, 4000,4150,4300,4450,4600,4750,4900,5050,5200,5350, 5500,5650,5800,6000,6200,6400,6600,6800,7000,7200, 7400,7600,7800,8000,8200,8400,8600,8800,9000,9200, 9400,9600,9800,10000,10200,10400,10600,10800,11000 ,11200,11400,11600,11800,12000,12200 (you can change these to match your MAF table if this doesn't line up with yours
    That should be it for the MAF one.
    For AFR error--I assume you have a wideband?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  13. #53
    Mar 2015
    New Jersey
    271
    Great. Thanks! Will give that a try. And yes, I have a Wideband.
  14. #54
    Mar 2015
    New Jersey
    271
    Do I put anything in the Row Labels? This is where im at so far.
  15. #55
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Do not put anything in for the row section.. take out what you have in there now
    Also note that the LTFT PID will NOT work until LTFT's enable.. usually around 133*. Nothing will show up in the histogram until then.. so don't assume it's not working right off the bat if nothing is showing up
    (without that PID working, the one you've setup for STFT+LTFT will not work either.. that messed me up. Just give it a few mins)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  16. #56
    Mar 2015
    New Jersey
    271
    Got it!
  17. #57
    Mar 2015
    New Jersey
    271
    OK. I think I got the MAF AFR Error one.
  18. #58
    Mar 2015
    New Jersey
    271
    I'm having an issue. The histo table comes up and looks fine until I start to log. Then it goes back to how it looked before I configured it. Here are 2 pics, one before I start to log and one after. Any ideas?
  19. #59
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    There's something that it needs that you aren't logging.. make sure you're logging MAF Hz, and LT & ST fuel trims for both banks
    Go to the table display and make sure all of those are in there.. Post a pic of it if you don't see anything wrong and I'll see if I see anything
    Also, go ahead and remove the PID.68=1 or whatever filter is in there for now.. just to be sure that isn't causing any issues
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  20. #60
    Mar 2015
    New Jersey
    271
    I will move this over to the other thread for simplicity purposes.
