the replicated cam signal to generate the signal for 93 siverado tach iam having trouble to work. The research ive gathered is a pull up circuit 680ohm to 1kohm.This does drive the tach but its pegged an still not sure why or what circuit i need design to get this working. There isnt many settings as only to enable an to pick one of four to aquire the signal from.
