Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
Thread: ARM architecture family
  1. #41
    Aug 2014
    6
    I can confirm VCM Suite works perfectly on my MacBook Pro with the M3 pro chip running Parallels 19 Pro and MPVI3. I just tuned my truck and currently running the vcm scanner for logs using this combo.
  2. #42
    Jul 2022
    16
    any updates on this i cant run my mpvi2+ on my new macbook air m3 on parrells running win 11 pro do i need too buy a mpvi3?
  3. #43
    Thank you!
    Quote Originally Posted by QuattroTDI View Post
    It works with MPVI2 on M2 !
    1. Download CDM-v2.12.36.4-for-ARM64-Signed-Distributable
    2. Extract the folder to C:\
    3. Delete device and drivers for USB serial port and USB serial converter.
    4. Reconnect MPVI2
    5. Manually update driver for the unrecognized UART device selecting driver on my computer and check the Subfolder checkbox with the path C:\CDM-v2.12.36.4-for-ARM64-Signed-Distributable
    6. Do the same for the unrecognized Port.
    7. Copy the 2 FTD22XX files in the x86 into C:\Program Files (x86)\Hp Tuners\VCM Suite
    8. Launch VCM and Tadam !
    OMFG! I just spent all f'ing day trying to figure this out, I was so agitated. Replies on this from HPT amount to "Just download the drivers from our website and everything will be just fine." They should be sharing your instructions, this worked perfectly. THANK YOU!!!
  4. #44
    28,779
    Quote Originally Posted by stephenasteiner View Post
    We do not support ARM processors, with that said I'm glad to hear that some of you have found workarounds.
  5. #45
    Feb 2020
    5
    Could somebody please help me with this? I just bought a Lenovo Yoga 7X with the Snapdragon Elite X, and my MPVI2 does not resync. I have attempted to follow the instructions on this thread, but I cannot get it to work. I am willing to pay for the solution to this.
    Thank you!
  6. #46
    Tuner 01 MidMet WS6's Avatar
    Jun 2007
    St Paul, MN
    173
    Quote Originally Posted by danielr96 View Post
    Thank you!
    Same here, MPVI3 works without issue. MPVI2 will not work with the current drivers using Snapdragon X elite. Would also pay for a solution for someone better with PCs than myself.
    01 WS6-M6, PRC Stage 2.5 5.3's, MS4, Kooks 1 3/4", custom built full true duals w/ X-pipe, SLP lid, tuned via HPTuners
  7. #47
    Aug 2020
    22
    I don't think the standard ARM drivers are going to work with the new snapdragon. Might be easiest to go through the MPVI3 upgrade program, or grab a cheap intel computer.
    Josh
  8. #48
    Jun 2007
    St Paul, MN
    173
    Quote Originally Posted by sook View Post
    Josh
    Yeah, I use it all day every day and my last XPS is getting to the point of dying. Didnt realize the snapdragon stuff uses different drivers. I will just upgrade my trusty MPVI2+ at some point.
  9. #49
    Jun 2021
    Wanted to thank persons here for their ideas it eventually led to me trying the right combination of things that worked even though my situation is different.
    I was able to get a new Windows 11 laptop (with just a normal x86 intel chip) working with the MPVI2. It wasn't detecting over USB, but my 10yr old W10 laptop and 5yr old W10 desktop detected it fine.
    On VCM 5.0.4 / Downloaded FTDI Windows (Desktop) x64 driver, version 2.12.36.4 from https://ftdichip.com/drivers/d2xx-drivers/ - The actual files, not the setup executable.
    In Device Manager -
    Uninstall and Update drivers on (Under "Ports (COM & LPT)" ) with FTDI 2.12.36 x64 for "USB Serial Port (COM3)"
    I think it was ftdiport.inf
    -Might not be COM3 - unplug/replug MPVI2 to confirm
    Uninstall and Update drivers on (Under "Universal Serial Bus Ccontrollers" ) with FTDI 2.12.36 x64 for "USB Serial Converter"
    Copied ftd2xx.h, ftd2xx.lib, ftd2xx64.dll under that driver download into INSTALLPATH/HP Tuners/VCM Suite
    Restart VCM - Resync now works
  10. #50
    Update: running Windows 11 with VCM 5.0.4. This worked for me:
    1) Download the latest Drivers: (for me this was 2.12.36.20A) under the "ARM column on this page: https://ftdichip.com/drivers/vcp-drivers/
    2) Open Device Manager on Windows
    3) Select the "Add Drivers" button at the top of the window.
    4) Plug in the MPVI2.
    5) Open VCM suite applications.
  11. #51
    May 2020
    3
    Quote Originally Posted by quattrotdi View Post
    it works with mpvi2 on m2 !
    1. Download cdm-v2.12.36.4-for-arm64-signed-distributable
    2. Extract the folder to c:\
    3. Delete device and drivers for usb serial port and usb serial converter.
    4. Reconnect mpvi2
    5. Manually update driver for the unrecognized uart device selecting driver on my computer and check the subfolder checkbox with the path c:\cdm-v2.12.36.4-for-arm64-signed-distributable
    6. Do the same for the unrecognized port.
    7. Copy the 2 ftd22xx files in the x86 into c:\program files (x86)\hp tuners\vcm suite
    8. Launch vcm and tadam !
    works!!!! Thanks!!!!
  12. #52
    Aug 2022
    24
    Another user here running an M4 Mac 16" MBP, latest version of Parallels Desktop and Windows 11 ARM. VCM Editor and VCM Scanner seem to work flawlessly. My MVPI3 connected without hesitation and performed a firmware update with no drama.
    Now I'm not sure if when I'd data log or write with the Mac as I don't want to beat it around and have a beater X1 Carbon for that job. The x86/x86-64 compatibility layer in Windows 11 ARM is pretty impressive, along with how well of a partnership apparently Apple/Microsoft/Parallels have.
    ...really thought I'd miss my i7 MBP.
