Results 1 to 7 of 7
Thread: Erratic MAF with SC
    Oct 2017
    Boston
    75
    Erratic MAF with SC
    Hello all,
    Noticed in my setup (09 Vette, LS3, A6, A&A kit, 9PSI, with Meth) the MAF signal is a bit erratic.
    I'm guessing it's what's causing the WB/AFR to jump up and down during WOT pull.
    Was wondering if there was anything in the tune that can be done to smooth-en it out a bit? Wishful thinking?
    Is this typical for these setups?
    Thanks,
    Pj
    C6-SC-MTH-Pj-7-5.hptDynoPullManual.hpl
    13,585
    Where is the MAF located?
    Could you put a air straightener in the tube?
    Jul 2020
    VIC Australia
    1,180
    For comparison purposes here is what mine looks like on a pull
    Oct 2017
    Boston
    75
    Looks smoother than mine. I've attached a PIC. I will look into an straightener...
    Thanks,
    Pj
    Aug 2010
    Detroit, MI
    947
    The MAF is picking up on noise because it's so close to the throttle body. Best solution is moving it upstream.
    Aug 2009
    Calibrating
    3,378
    A honeycomb screen will greatly help…
    That or do a smaller tube (3.25 or 3.5), you have a 15000 hz limit so will work fine on the big end..
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Oct 2017
    Boston
    75
    Thanks all. I ordered a straightener with MAF bung and will try to place it back a bit away from TB. I'm guessing you don't want it too close to the bend either...
    Thanks,
    Pj
