Results 1 to 6 of 6
Thread: C7 GrandSport : Manual gearbox swap Z51 to Z06 : Table 20090 not working ?
    Hi,
    I have 2017 C7 GrandSport where I already put a Katech stage 2 engine, which I successfully tuned.
    I do not like Z51 gearing that comes with the GrandSport, so I bought and swapped myself the crappy geared Z51 gearbox for a Z06 gearbox.
    Gearbox is the same, only the ratios are different.
    I thought this was going to be very straight forward. Normally I should just have to go to table ECM 20090 in the Trans menu and put my updated ratios.
    I did, but it looks like the ECM is not taking the new values. I'm getting " reduce clutch usage -power reduced " messages on the DIC and sometimes DTC " 5th gear wrong ratio " on other.
    I data logged everything and :
    - Output trans shaft speed is good and consistent
    - Clutch position stays the same when it happens
    - Calculated ratios between engine rpm and output trans shaft RPM is the same as the entered ratios in table 20090
    - Clutch is not slipping even a bit
    I'm excluding mechanical or electrical/sensor issues.
    I did a test putting back standard ratios in table 20090 and I have exactly the same issue. Which tells me the new ratios are not registered by the ECM when I flash.
    What do you think ?
    - I submitted a ticket to HP tuners technical support and they answered me they will look into it but I bet it will take weeks or months
    - I only tried " write calibration " like I always do. Can write entire change anything and is it risky to do it ?
    - Is there something I'm missing ?
    - Is there a way to use a M7 Z06 file and flash it to my GS since it's the same ECU, then putting back my tune values in all the tables ? I'm assuming this would create a whole bunch of potential issues because the GS does not have the supercharger and I would be missing several sensors and actuators ?
    - I know some sequential swaps on GS, there must be a way to trick the system so the ECU does not look at the ratios ?
    - Temporarly is there a way to disable this reduced power mode ? I know I can disable the DTC for wrong ratios but I bet it will not prevent to cut power...
    I've been thinking a lot about it lately and contacted some experienced tuners on the forum, I'm willing to pay to get it resolved as I have racing events (AutoX and Roadcourse) next week, but no one is answering me... There must be a solution somewhere, this should be a damn simple swap !
    7,818
    Probably needs a segment swap, there's lots of code behind-the-scenes that isn't reflected in any tables or settings visible in the editor.
    Which segment would you swap ? You don't have a transmission segment for manual transmissions...
    I found a C7Z file with the same OS than my GS and the files I have :
    - System
    - Fuel system
    - Speedometer
    - Engine diagnostic
    - Engine operation
    By swapping the engine operation segment I was able to get the Z06 ratios in the trans menu. Now will it work if I change all my tables back to LT1 ???
    Answer : it works. Had to rewrite all the tables though.
    i spoke too fast. Running the Z06 program creates all short of other issues on the fueling/TPS and some sensors (knock retard sensors are not working anymore)
    Gearing works but too risky for the rest...
    I'm back to square one...
