Results 1 to 7 of 7
Thread: Gen 3 LQ4 w/ (12613412) 50lb Injectors - Looking to get some info.
    Mar 2022
    Colorado
    3
    Looking at some tune files from previous posts [[https://forum.hptuners.com/showthrea...fo|Reference]] I noticed some funky differences in the Fuel Voltage Offset tables of some different commenters on the thread. These all seem pretty different, and I am looking for some insight as to why. Thanks so much, I look forward to engaging with you all much more often.
    7,821
    Return style regulator or returnless?
    Mar 2022
    Colorado
    3
    Returnless @58psi.
    Advanced Tuner Matt Vardaman's Avatar
    Mar 2021
    207
    Quote Originally Posted by Goosenoose View Post
    Returnless @58psi.
    Here:
    00 Trans Am GM#12613412 Injector Data (1) returnless.hpt Returnless
    3-20-22 2002 Tahoe flex spark adj maf adj.hpt return
    Compare these two
    2001 Silverado 5.3 - 209/217 cam, GT45 Turbo on 7lbs, Aem x-series wideband, 50lb/hr flex fuel injectors, on E85 with content sensor
    1999 Silverado 6.0/4L80E Summit Stage one camshaft, 317 heads (replaced cast iron)
    Mar 2022
    Colorado
    3
    Quote Originally Posted by Matt Vardaman View Post
    Thanks for the two to compare!
    I will take a dive into the tables and see what comparisons I can make.
    Dec 2008
    on the Dyno
    1,825
    Mine is derived from OEM GM Cal data. Here is the OEM Gen4 table for those injectors. Have no clue who generated the others but I trust the OEM data over anyone else.'412 Injector Data.png
    Located in Central Kentucky
    ShorTuning
    Jun 2016
    24
    Quote Originally Posted by LSxpwrdZ View Post
    Isn't that offset table you posted for the L92 12609749 injectors? It was noted here that they were slightly different than the L96 12613412 injectors and I noticed that the voltage offset tables are different. Does this affect much? See other post here:
    https://forum.hptuners.com/showthrea...tor-info/page2
