I am trying to make a histogram to calibrate my maf using MAF period. I have it in my channels and my chart logger but both the voltage and period stay at zero. But it is giving a MAF reading and a hertz reading. Anyone know why this might be?
can you post a pic of you histogram your trying to use
so what's happening is it will only log the first cell. so I checked my channels and they are all in there but the MAF period and voltage stay at zero but I am getting an airflow reading and a hertz reading and no CEL or driveability problems
here is a pic of my STFT+LTFT histogram, I was just trying to figure out why my MAF period wont read.
here you can see that i am not getting a MAF period reading or voltage.
the first link didnt work properly, the second is good
[QUOTE=Owiens;682100]the first link didnt work properly, the second is good[/QUOTE
I have seen this issue happen a couple times, Try updating your software if haven't already. Might need to re build the channels. It a 6.2 Raptor so it should be able to read the MAF Period. What i attached is STFT B1+B2 vs MAF Airflow LBS/Min. it's no the most accurate but its a last min pinch.
I havnt done anything for a while now but i decided to try this again. i did all you suggested and stil cannot get MAF period or MAF Voltage to read. anyone have any ideas?
