Results 1 to 3 of 3
Thread: Cammed Dodge Ram stalls when coming to a stop or mid turn.
    Jun 2018
    611
    2010RAM.5.7.CAMMED.hptJEFFS.CAMMEDRAM.002.hpl
    So I have a Dodge Ram I'm working on. It was previously tuned by someone off the internet. Truck has headers and a cam. Customer was complaining the truck was back firing. Changed a buggy o2 out but the truck seems to stall (owner said this was an issue too). When it's cold it seems fine but once it warms up it'll die when coming to a stop or mid turn. I pushed the idle up to 800 minimum and it still does it.
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by JASON11WS6 View Post
    https://youtu.be/WzNJreZYLv4
    Go to torque model
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    add throttle body air (10 to 40lbs) from 0 to 0.50 volts or go to torque model friction torque base and set 0 to 1600rpm to 5ft lbs and blend out. This table induces a throttle hang from experience. Restore your idle PID numbers to stock if altered. Should help.
