Results 1 to 9 of 9
Thread: 6R80 swap on a 2005 expedition it is posible?
    Nov 2008
    Tampico Bay, Mexico
    221
    hi any one that can tell if is this swap posible or i just bite the bullet and overhaul my old 4r70w ... I have acces to 6r80 from 09-10 trucks so i just need to know if the pcm or modules are compatible with this kind of swaps ...i mean on chevy i know i can swap a 4l60 to a 4l80 or even a 6l80/90 but on fords im on the dark so any info from the big dogs on ford that can share some knowledge??
    sorry the truckis a 2005 ford expedition 4x4 5.4 3V withthe 4r70w and electric transfer (i dont mind putting a transfer shifter if is necesary)
    all the way from Tampico bay Mexico
    Tuner Lost0187's Avatar
    Oct 2021
    Canton Ga
    171
    You would need a pcm from a 09-10 f150 or expedition navigator. But If you have access to a 11-14 you can use a copper head or stand alone quick 6 inline with the pcm. The trans has a mechitronic unit on the 09-10 6r80 and differs from the 11-14 on the valve body. The 09-10 6r80 uses HS can to operate the tcm and data is sent to pcm. The 11-14 uses pcm to control 6r80 (copperhead 2048k) You will have to move pins as well as get the 09-10 pcm or 11-14 pcm and lead frame for copperhead setup as well as pcm connectors either way. The quick 6 is great also but it has to be a gen 2 unit the unit is a lot better and parameters are also. With the 09-10 pcm you will need 2 wide band o2s and the tcm harness some are separate on the f150 and together with engine harness on the expedition I?m pretty sure. If you need help let me know have wiring diagrams it?s different from 09-10 pcm vs your 05. It?s a ton of work to be honest I have done something similar in upgrading my 6r75 08 expedition to a 14 6r80 and I?m using both a copperhead pcm and quick 6 linked together to get data to the pcm and to the standalone.
    Nov 2008
    Tampico Bay, Mexico
    221
    damn Lost0187 its a lot of work but i can do it ..... maybe im gonna need those diagrams i was told that the very first 6R has the tcm apart and thats the one i can get to work here but i think im gonna have to double check that data
    Aug 2021
    Lee’s Summit, MO
    Hello, I am swapping a 6r80 into an 05 F150 4x4. I understand that I will have to change some of the pins in the tcm harness. Do you have the necessary diagrams? Thanks
    Oct 2021
    Canton Ga
    171
    If you are planning a 6r80 swap on your 05 F150 there is a little more to it than just a simple pin swap ill try to guide you on what needs to happen.
    A: What year 6R are you going with 2007-2010 or 2011-2017
    B: Using a 07-10 6R might be more ideal for your 05 F150 application here is why you can take a 2007-2010 Expedition, Navigator, or F150 PCM make a some changes to your original harness and make it work.
    C: Using a 2011-2017 6R he is where it gets in-depth so you want full control of your 6R select shift the whole 9 yards this is gonna take a lot of changing to make happen and for most its just not worth it.
    D: Drive shaft the 2009-2014 F150 should work fine the only obstacle might be the transmission mount to the frame but that should not be from what I've seen on the 05-08 F150
    My advise get a TCM controlled 6R 2007-2010 and link it with your original PCM which might take some work or go simple and get a 2009-2010 F150 PCM then just grab the harness of a yard truck and the trans harness this will be really like under 10 wires that you will have to run at most.
    If you need further assistance you can message me and Ill try to get you on the right path with your 6R
    It seems like a lot of work but its not to bad and the truck will drive amazing vs the 4R70W
    King Ranch Expedition 5.4 3v 6R80 Coyote PCM , M112 Blower, Kooks Long Tube Headers, Green Cats, Aeromotive Regulated Return Fuel System, ID 1000 Injectors, Custom Interior Wiring, Track Apps, EPS mode adjustable, +6 Blower Pulley w/ Innovators West SFI Balancer, Afco Dual Fan ZL1 Heat Exchanger, Flex Fuel E85 0-60 5 secs 12.0 best quarter mile time.
    Mar 2024
    What?s the easiest way to swap the 6r80 into an 08 f150, taking an 09-10 f150 computer and engine harness would work? Is there modifications you have to make? I?m building my motor right now with H beam rods and forged pistons, gonna do a turbo setup with deleted vct plates from the v10,
    Oct 2021
    Canton Ga
    171
    You can go that route the only other thing you may want to keep in mind is you may also need a abs system from the donor truck seeing as they go hand and hand the 6R and HCU ABS module. If you have any more questions you can DM me and ill do my best to help get you on the right path.
    Aug 2021
    Lee’s Summit, MO
    Thank you for responding to my post. For some reason, I can?t send you a direct message. I have a 6R80 and tcm harness from an 07 Expedition. I understand the easiest way to do the swap is to use an ECU and engine harness from an 07-10. I know I need to rearrange some pins, but I don?t know if I need to swap the ABS module and transfer case. My F-150 has a BW 4406 transfer case and the 07-10 use the BW 4418. Any advice is greatly appreciated.
    Oct 2021
    Canton Ga
    171
    You can email me if you cant DM me its [email protected] I can help you get everything up and running some changes will be required to get everything working like factory but its all possible.
