Results 1 to 20 of 33
Thread: what im i missing? idles high and have to push gas to get it to start.
    Jul 2017
    35
    have to use the peddle to get it to start and once it starts gas peddle no longer works and it idles way to high?
    this is my first time tunning and this is a first start on a 5.3 gen 3 all alm with a sloppy stage 2 cam swapped in to a 740 volvo
    its dbw the peddle, brain and throttle body all out of same truck.
    Stock throttle body? Recalibrate your tps sensor so its 0% at key on.
    2000 Camaro SS 408 TH400
    2012 Subaru WRX STI
    2013 Camaro SS
    2001 Corvette Z06
    Jul 2017
    35
    Quote Originally Posted by 99CamaroSS View Post
    this is drive by wire? do i still have to calibrate the tps?
    Didn't have time to look through everything but try adding to your base running airflow. I have seen that cause a DBW TB to not zero out if it has too much error. They do have a run for 3 minutes and off for a minute and run for three minutes calibration also.
    2012 Subaru WRX STI
    2013 Camaro SS
    2001 Corvette Z06
    Jul 2017
    35
    my dive by wire works with the car on but not running but does nothing when its running?
    13,565
    Both data log shows the MAP stuck at 85kpa, that's an issue.
    Not sure why you zero'd the P0121 tables in the engine diag tab either.
    I think some of your DBW codes are turned off too.
    Jul 2017
    35
    i dont have a map that was deleted in my harness.
    Tuner BigTuner's Avatar
    May 2020
    Indiana
    111
    That doesn't sound right, you are going to need a MAP sensor, do you mean MAF delete? I can't look at your tune right now.
    Jul 2017
    35
    yes sorry i have no MAF do have a map
    May 2020
    Indiana
    111
    Okay that makes more sense, then as 5FDP said you need to solve why it is stuck at 85 kPa, it is a VERY important sensor.
    Jul 2017
    35
    so i have 3 map sensors tested all 3 in another car and they work (one came out of that car) but none work in my car. tested teh pin out and it was wrong so i fixed it so first wire has 5 volts middle has ground and 3rd dont know how to test? but it wont start at all now??? im so lost
    13,565
    Are they all OEM ac delco map sensors from say a LS1, 4.8/5.3/6.0 engine made before 2007.
    Jul 2017
    35
    2 have the same part# for ls1 and the stock one form the 06 silverado
    7,640
    If you jumper 5 volts to the MAP signal return, does the scanner show the MAP value go high? And jumpering ground to MAP signal makes it go low? (yes, the MAP signal has an internal pulldown resistor so it should go low with the sensor unplugged/open circuit, but this is just the basics of how you do a bypass test to check a PCM signal circuit)
    I posted MAP wiring/pinouts in your previous thread.
    Jul 2017
    35
    ok in the pic you posted i have to ask a dumb question? is a or b the ground? i know i have c in the right spot.
    https://forum.hptuners.com/showthrea...to-a-volvo-740
    then with the scanner on and the key on i just put a jumper form c to signal and then ground to signal to test if the pcm is working right did i under stand that right?
    thanks again you have been a huge help!
    7,640
    'Low reference' means ground. The middle pin is the signal output back to the PCM. If you jumper the 5v reference to the signal wire, the PCM should show whatever max MAP value it can read. Remove the jumper and it should go back to the minimum it can read.
    It would probably not be a bad idea to unplug the PCM, too, and check with an ohmmeter that MAP 'A' goes to PCM C1 54, MAP 'B' goes to C2 32, & MAP 'C' goes to C1 48.
    If you're already in this deep and just now figuring out how wiring diagrams work, I don't envy you.
    Jul 2017
    35
    so it does nothing when i jump 5v to the sig wire and does go up to 3.6 when i plug the sensor in. then goes back to 1.5 when i unplug it and does nothing when i jump the ground to sig? so next step is to test the 3 wires to the pcm like you said. but looking to me like the pcm is bad?
    7,640
    That's... not possible, unless you have the wires identified wrong. Did you check that the 5v wire has 5 volts, and the low ref wire has continuity to ground? The signal wire should have 0 volts with the sensor unplugged, but not a true ground (PCM pulls it low through a resistor).
    Jul 2017
    35
    yes 5v tested in the right spot ground tested and in right spot. you can watch my hpl only change ever to it was when i pugged sensor in?
    Jul 2017
    35
    ok i checked my pin outs and2 where wrong and now fixed. (again could not have done this with out you!) tested it again in the log started with unplugged then pluged sensor in the unpluged it then jumped 5v to sig wire went way up then jumped ground wire to sig. does this all look normal now? also tested all 3 sensors and they are .1 of each other and right around 12 with car off.
