Results 1 to 4 of 4
Thread: 2017 F250 6.2 help
    May 2022
    2
    2017 F250 6.2 help
    I am new to tuning fords and just want to make sure I am understanding what I am reading. When I go under Engine, Airflow, Electronic throttle the throttle angle max is set to 85 degrees. So would I be okay to set it to 100? 95? Now when I click the table it shows it is set to 90 even though the limiter reads 85. Sorry I am new to the forum and don't know how to post pictures once I figure it out i will so I can help you guys understand my question. Thanks for your time.
    Feb 2012
    TEXAS
    638
    You can but, the throttle body has a hard limit of 90-92* no matter what you set the Max axis.
    May 2022
    2
    Okay, thanks for that information. This is a work truck but we also want a little more from it. Other than messing with fuel and timing what can I do to make it react and maybe give it more pep so to speak?
    Feb 2012
    TEXAS
    638
    Quote Originally Posted by Razzburrys View Post
    you could ad some more timing down low a couple degrees, makes some general temp adjustments, some other minor tweaks.
