Originally Posted by
tmanplanet
u would have to contact customer support in regards to licensing if you have any vin issues. honestly i didnt look for viper tunes much but there are many different sources online that would be able to use the tune delivery network to get it up and going. does it read the vin with a standard scanner like autel? USEING Repository TUNES IS AT YOUR OWN RISK, i dont recommend it. curious if u can read the vin with a scan tool. there are other ways to trick the pcm into thinking the cats are fine like useing a spark plug defouler that u drill out the hole so the o2 sensor can still read but is out of the stream, there are different sizes/lengths. also the pcm is looking for certain values so a inline resistor of sorts could give your pcm the correct values... unfortunatly u cant just wire the wires together LOL
