I did as you suggested, mstang_man, and copied the MBT table into the Borderline Knock table. The engine runs well, wideband shows close to lambda in closed loop. Long term fuel trims are close to zero, spark advance ranges from 45.5 to 13.0, depending on load. At steady throttle in closed loop, timing is in the 26-32 range. During WOT pulls timing is about 22. How do you usually proceed from here? ...regards, kevin
