Having issues with my 2008 LS7. E38 Ecu, msd intake, 102mm TB, heads cam. This is in a 67 Camaro.
Sometimes when running on track or autoX engine goes into REP or just stops. If it stops it won't restart in a minute or so. Coolant is around 190 or so. Headers etc is just hot from running hard.
Initially I thought it was a fuel issue, but I have a fuel pressure gauge and a manual override switch on the fuel pump relay so i can hear it run.
I have also tried to swap crank pos sensor, but it still stopped.
Looking at the log there is a P2119 code. Can my TB give me these issues? It is running fine until it doesn't, and after a restart it runs again.
Anyone?
Can tolerances on the P2119 be tuned out
