Results 1 to 20 of 21
Thread: Adjusting cooling fans to operate at highway speeds if needed?
    Gentleman,
    This is for 09' GMC SIERRA 2500HD with stock E38 computer. It uses factory dual fans setup. Everything is tuned as stock (same as 1500 Series trucks).
    These are the only options I got to play with for cooling fans:
    1- Fan Desired % vs. AC Pressure
    2- Fan Desired % vs. ECT
    I have discovered through the scanner that the factory default OFF for the fans is when the speed reaches ~45 mph regardless of the other two parameters, I need to know if I can alter this. If so, please let me know in details and which beta will support this? I think maybe if I update the software/beta other parameters may be visible? If anyone has any experience directly related to this, please let me know. I'm sure others would benefit.
    Thanks!
    Jul 2020
    VIC Australia
    1,196
    A clear log with the above parameters would be handy.
    In your examples does the AC pressure and or the ECT PWM setpoint put into a fan state where at least 1 fan should be commanded on?
    If yes, the fans are reporting off in the scanner?
    If yes, then you are right and it looks like we are missing another table.
    The OS I've seen does not reference speed at all but it does reference EOT and TOT as well as AC and ECT. We don't have those tables mapped either. I have seen another OS where the EOT and TOT tables were zero'd out so not all OS's use them.
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    There are many Gen 4 fan modifiers - as hjtrbo has indicated.
    With Gen 4 calibrations there are vehicle speed related fan modifiers (often not defined in HPT) that can inhibit fan operation.
    Corvette calibrations always have these parameters set to the maximum speed - such that fan operation is never inhibited by vehicle speed.
    Gen 4 Truck calibrations may sometimes have nonsensical vehicle speed fan modifier settings. This may sometimes included a short range or "window" where fan operation is inhibited by vehicle speed. The most common "window" inhibits fan operation between vehicle speeds of approximately 50 MPH to 65 MPH.
    In your case the lower end of this range seems to be around 45 MPH. If you were to drive the vehicle on a highway, at 70 MPH (or more) - you may find that fan operation is no longer inhibited by vehicle speed.
    hjtrbo,
    In our trucks, both fans are either on/off in low and high speed. They are relay controlled. The set points for AC and ECT work flawlessly as intended/programmed, but my issue is on speeds above 45 mph where it neglects the previous parameters and shuts the fans off permanently regardless of the set points in (AC pressures and ECT). Unless speed is reduced to ~25 mph, where it will now depend on the AC pressures and ECT so when speed comes into play, everything else is disregarded. This is not very desirable in my opinion, say for example the coolant temperature reaches 220 Fahrenheit, I want the fans to kick in. By the way, I realized that 2007 to 2014 YUKONS/TAHOES E38 ECM is set to work this way from factory, but I wanted to know if they are adjustable somehow but is not showing via HPtuners parameters? EDIT: To share accurate information to fellow HPtuners Members; I've just learned that my above statement/issue apparently involves 2009 through (2013 SIERRAS); (2014 YUKONS/TAHOES). So 2007 and 2008 models in fact do implement the tables I need for the 'Vehicle Speed Adjust' as per Shrek's shared information. C6 Corvettes too implement these fan parameters.
    Oh yes, they are showing their states via the scanner and they are right on; applying the tune.
    Shrek,
    I have seen the C6 CORVETTES work as you mentioned. I like that, well their fans uses PWM but it doesn't matter. I wish my fans work the same way but in low speed and not shut off early at 45 mph. I'm thinking something like: OK shut off at 45 mph, but if the temperature reaches 215+ then keep the fans running at low speed then shut off at 205 F. and so on.
    If you know how I may apply: "vehicle speed fan modifier settings" please let me know.
    Thank you both for sharing your thoughts
    Bader
    Nov 2011
    753
    Regarding Gen 4 E38 ECM vehicle speed fan modifiers.
    If you look at 2008 E38 OS 12617631 - the above are defined for both Corvette and Truck calibrations.
    Go to System > Fans > Vehicle Speed Adjust
    Look at:
    ECM 8052 - Vehicle Speed Lo
    ECM 8053 - Vehicle Speed Hi
    ECM 8054 - Vehicle Speed Max
    Your 2009 Truck is likely using E38 OS 12630501.
    The above described parameters have not been defined by HPT for 2009 E38 OS 12630501. You would need to submit a support ticket, and ask that these parameters be added.
    Jul 2020
    VIC Australia
    1,196
    Hi Shrek, would it be possible for you to post both of those OS's? I can get the binaries from those files and should be able to find the addresses if the offsets aren't to far apart. If I can get those addresses to the OP HP support will implement those tables alot faster.
    I'm glad you mentioned all this as now I will look for those in my binary and add them to my UDPs. They will come in handy for my interchiller.
    Mar 2022
    Olathe Ks
    94
    I am also interested in this for my 2014 Yukon Denali. E38.. It runs so freakin hot while towing at highway ish speeds around -55-60 mph..
    I know for sure the fans are NOT On. If I get into a little town or something and slow down, the fans come on a temp go back to normal.
    It concerns me that my ECT's run 220-230 while towing because then my trans temps go up to.. And I have a very large mishimoto all alum radiator..
    SO it's not a coolant flow issue at .. Strictly airflow at the speeds 45-65 mph.
    Quote Originally Posted by Shrek View Post
    Look at:
    You got me interested regarding submitting a support ticket to add the specified parameter. Although I have never done this before, is it something that will be available for the public within the next beta update or how does it work? Assuming HPtuners will approve it and work on it. I really don't know how this gets done.
    Thanks for your feedback!
    Bader
    Jun 2023
    6
    Is it ok to bump this old thread? I can't find anywhere what does ECM 8052/8053/8054 stand for.
    I only want my fans to run by ECT, not by speed or anything else, how can I do this ?
    Couldn't find info anywhere
    Oct 2023
    16
    I've got the same issue with my 2012 Yukon 6.2 E38. Only fix I've found so far is to just adjust the override parameters from 240 or whatever it was stock down to 220. I may go down to 216 and call it a tow tune. I logged for about 3 hours of towing at 50-65 and the fans were off 90% or more of the time, only coming on when the ECT reached my 220 set-point.
    Mar 2022
    Olathe Ks
    94
    YUP, that's what I ended up doing as my 14 yukon denali had NO settings for MPH/Speed in correlation to fans
    I went into the "override parameters" to set my fans to come on at about 218 ish.
    I just haven't towed in hot enough weather yet to test if they actually are commanded and do come on as intended by me.
    My trans temps were horrible while towing heavy in the 50-65mph range with no way to cool down when ect would go up to 220+.
    I did add a separate trans cooler with a fan (mounted underneath and got rid of the external trans cooler in front of the radiator).
    Now I can turn on my trans cooler fan anytime I want independently - stop & go traffic, towing, idling a lot while hooking up, whatever
    Mar 2006
    Detroit
    1,038
    A 24"x24" radiator being pushed down the road at 50mph sees 17,600cfm of incoming airflow without the fan. If you are having cooling issues at this speed, I seriously doubt any commercially available radiator fan is going to help that much. I would concentrate my efforts elsewhere.
    Mar 2022
    Olathe Ks
    94
    Unfortunately this is how the SUV's air flow system is... There's no way to get 24x24 Air Into the Radiator
    past the bumper/cover/ etc . Then past the oil cooler, the ps cooler, trans cooler and to the radiator.
    I even have a really nice mishimoto radiator, upgraded trans pan/cooler etc...
    I was not concerned about the engine temp as much as the trans temp.
    Now I have added a derale trans cooler with it's own fan on a switch (NOT in front of the radiator) and I can turn
    it on anytime (only need to when towing my 9500 lb camper)
    I understand that going 50 mph pushes a ton of air, but in some circumstances it's just not enough
    I have not gotten this hot since I relocated my trans cooler so I can't say for sure if overriding the fans at speed
    helps or not as I haven't got hot enough (yet) for them to turn on a hwy speeds.
    Absolutely not trying to argue as you are a true veteran on this forum.. It's just a specific scenario here
    SoCal
    1,617
    Quote Originally Posted by Tfoggy View Post
    https://www.summitracing.com/parts/d...RoCJ2gQAvD_BwE
    1,567
    I don't think adding any fan to 50+mph will make a difference.
    Mar 2022
    Olathe Ks
    94
    That switch came with my cooler. I didn't use it... As I want control over it (ocd)
    When i know a large hill or something is coming up I can flip it on before all the heat so I'm not
    trying to chase down good temps, Get ahead of them
    Oct 2023
    16
    Quote Originally Posted by eficalibrator View Post
    Bro, I can literally watch the temps climb from around 211 to 221 where the temp override comes on, then rush down to 211 where the fans turn back off.
    Keep in mind this isn't a 3rd gen Camaro or C6 that slips thru the air.
    It's a brick of an SUV towing a 6000lb brick of a camper up hill.
    The fans help. Significantly. I have a short log showing how well if you are really truly interested.
    Oct 2023
    16
    You'd be wrong. I have a log proving it if you really want to argue. I logged for 3+ hours of towing and can easily watch the temps creep up to 221 until temp override is triggered and the fans come on, then they rush back down to 211.
    Mar 2022
    Olathe Ks
    94
    I'm glad someone chimed in with real world use.. I haven't been able to test my override fan settings... yet...
    Gotta get warmer with the camper on. But glad to know that it does help. Thanks !!!
    Mar 2006
    Detroit
    1,038
    Quote Originally Posted by Gordon-0 View Post
    If your engine is getting to 211+ with a 192* stat, you are already behind on cooling capacity. I have done plenty of OEM powertrain development work, and yes, I've also seen cases where we had no option but to add fans to try and squeak by on cooling capacity. All of those programs would have benefitted from either a better radiator, better airflow management through the radiator, or both. Cost usually won in those cases. In the performance aftermarket, we have the option for relatively modest cost upgrades that can make a real difference. I would start with better ducting to ensure that all the air entering the front grill MUST go through the radiator instead of leaking through lots of the gaps around it. That doesn't cost much and can make a huge difference. The trick is to make the best use of that ~17k CFM of cooling airflow whenever possible.
