Results 1 to 3 of 3
Thread: Couple of Quick Questions
    What is the conventional wisdom on selecting the HPtuner stoich value in areas where all we have is gas with about 10 percent ethanol?
    14.2 or 14.7 ??
    I have read discussions of GM two bar map sensor offsets, without there ever being a conclusion or explanation of when one or the other is used.
    10.33 or 8.33 ?? Is it dependent on the altitude (barometric pressure) of your location?
    SoCal
    1,585
    I use 14.2 but I also run a little leaner on PE to compensate. All comes out in the wash with a wideband
    8.33 offset works for my altitude and barometric pressure around 91 kpa.
