Results 1 to 5 of 5
Thread: Options on OS files
    Oct 2019
    29
    Options on OS files
    I grabbed a junkyard 5.3 and i have a spare ecu that i used for my racecar...... upgraded it to a 3 bar OS
    Engine currently has a standard 1 bar os.
    Im trying to get the engine to run without being pig rich
    I dont have a MAF pigtail so its currently SD.
    Is there any way to either
    a] downgrade OS to 1 bar
    B] change map linear to 1 bar and give it a whirl
    c] copy everything from 5.3 file and make it work?
    D] interpolate fuel table all the way to 315 to fool it into thinking its just a really big 1 bar map?
    I do have a 5.3 ecu MAF, but i don't feel like spending $100 on credits to make it run
    Thanks in advance
    13,588
    1. You need the stock file to go back to the 1 bar OS, if you have that file you'd just do a write entire to make it stock again.
    2. Changing the linear and offset settings would be easy to make it run on the 1 bar MAP again.
    4. You could copy the stock VE back into the 0-105 KPA section of the 3 bar VE table and it should run just fine doing that. You can't make the 3 bar table into one really large 1 bar ve table.
    As a side note, the 5.3 MAF sensors have a IAT sensor in them so you must install a IAT sensor into the intake somewhere. All fueling calculations factor in the intake temps, so you need to have that working.
    Oct 2019
    29
    LUCKILY i fired up my laptop and there the stock file was..... just chillin. lol
    Flashed back to single bar....... forgot that this was a 6.0 ECU...... is this just a simple os swap to 5.3?
    As for the IAT, ima go to junkyard tomorrow for a pigtail and splice it into the harness to get maf back
    13,588
    Don't swap the OS, that costs money.
    Just find a stock file with the matching OS but in a 5.3 file. Then just use the compare feature between the two. The compare function lets you copy over all the engine side values to a 5.3 in like 3 clicks of the mouse.
    Oct 2019
    29
    gotcha, thought it was a OS swap..... ok cool, sounds good, thanks! i use the compare file alot on 1 of my ECU's here at home lol
    thanks for the help!
