I haven't touched my tune in quite awhile, so I'm a little rusty on my LS1 knowledge. But I changed injectors, so I'm back into it now for a bit.
I'm having some weird LTFT issues/observations when running the car in SD mode, and curious if anyone help point me to WHY, it would be greatly appreciated. It's not a huge issue, I'm mostly bothered because I can't understand what's going on exactly.
P59 flex fuel (-7603 OS), 2003 Corvette Z06. Mild cam, LT headers, pretty standard setup. LS3 MAF.
The car was running a 'normal' tune with MAF enabled etc. Ran the car with MAF enabled' +10 LTFT or so in idle regions, but that was about it, no issues really.
Flashed to SD COS, failed the MAF in order to run speed density. To both tune the VE table and compare how it ran/see if I wanted to run SD mode.
When running SD COS/MAF failed, it needed around 15-20 percent fuel pulled at idle. The weird issue: LTFT pegs at -8.6% and will never exceed that. So for example, LTFT will hit -8.6 and STFT will continue to pull around 6-8* fuel or whatever. When I shut down the car, LTFT resets to -1.6% every time, for every fuel trim cell (that were all 'maxed' at -8.6% on previous drive).
Is this a SD mode thing that I'm totally misremembering, that LTFTs don't quite work right? I don't think this can be right, but driving myself nuts trying to figure out what's going on.
I haven't touched the LTFT min/max limits, which are set to 0.8 and 1.25 IIRC. Which should mean -20 to +25 LTFT range.
I can post a tune/log later when I'm back on the PC, but the only changes between my 'MAF' and 'SD' tunes are failing the MAF and I zero'd out the MAF table (which probably isn't necessary, but I don't think that would be related either)
