Hey all,
I have a 2018 Dodge Charger GT with a slightly modified (ported upper and lower intake manifolds and TB, CAI, Coilpacks, and exhaust) 3.6L Pentastar engine in it.
I am curious if anyone ever really utilizes the VVT spark tables, I've seen in multiple places people recommending setting them to all the same values and leaving them, is that really the best thing to do, or is it just the easy thing to do?
My thought here is that you could tune these tables individually, then throw them back into the "main/master" tune file and be able to throw the cams all over the place without really having to worry too much about adjusting the spark every time you make a cam adjustment.
In my head the process looks something like this:
1. Create a tune file for each VVT spark table
2. Set both cams to be at lockpin position at all times
3. Set all spark tables to be equal to the stock lockpin timing
4. Tune the VE table in the NN
5. Tune spark
6. Record the results into a "main/master" file
7. repeat steps 2-6 for each VVT spark table.
My theory is that process would result in the ECU being able to adjust the spark accurately for whatever cam timing you throw at it meaning you could then tune each of the rest of the VE tables in the NN without touching timing.
Am I on the right track here or am I way off base? Is this way more work than necessary and not worth the time and effort that would go into actually accomplishing this? Are there any gaping holes in what I'm saying here where I could end up damaging something if I tried this? I'm relatively new to tuning so if I'm way off base PLEASE TELL ME.
Thanks in advance for any help/feedback on my ideas! I really appreciate it!![]()
