Got an 01 LS1 Camaro, usual heads/cam type car, with stock MAF and 30lb Ford injectors (so "34" lb rating on the GM).
The car is tuned and everything is nice, except for one issue. On startup, the car will go into CL quickly and then shoot up to 18:1 a/f for a minute or two, and afterwards it will drop back down to stoich as it should be and run normal. I tried playing with a few startup fuel parameters, but they didn't seem to make a difference.
Does anyone have any ideas? Thanks!
