When I try to view my LTFT and STFT hystograms in HPT, I get text telling me that I must not have all the proper sensors setup. Which sensors are required to get ST & LT FT data?
Thx all... Gawd I feel like such a nub.
-Eagle
-Eagle
2011 Z07 Carbon Edition
just load the default config.
otherwise you need to log ltft, stft, rpm & map.
Thanks Bill! I'll give that a shot when I get home. I tried loading the default config, but that didn't seem to fix it.
I jacked it up when I started trying to figure out what I needed to do to calibrate my MAF sensor...
My bet is I took out the MAP sensor.
Thx again,
-Eagle
The key was that I needed to have 'Manifold Absolute Pressure (SAE)' which reads kPa - not 'Manifold Absolute Pressure' which reads voltage. Thanks again!
-Eagle
