Results 1 to 13 of 13
Thread: HP Tuner Hardware Versions?
    If I were to buy an HP 'Tuner' from a person I know (non-pro version) would the version of the actual hardware matter? Like say the scanner/flasher thing is 2 years old: could I still use the new software with it? And would it have any limitations compared to a new one?
    Thank you guys so much! This is my first post
    28,772
    Yes you can use the software right from the customer login page at www.hptuners.com
    Nov 2005
    Houston, TX
    3,968
    Is it the USB or serial interface? The latest software is compatible with either but you would not be able to tune some vehicles with the serial interface (EG: Gen 4 LSx's).
    Bill Winters
    Out of the LSx tuning game
    28,772
    Quote Originally Posted by 5_Liter_Eater
    USB & Serial interfaces use completely different software & is not compatible.
    Nov 2007
    Houston
    4
    Couldn't find it in a FAQ See my sig , but when you order the pro do you get both the serial and the USB cable? I think I need the USB.....
    One other ques, do you get "all" the adapters to hook up to the supported cars trucks etc interface port?
    2006 VR Coupe Z51 MZ6 3LT
    Aftermarket Security
    Standing Texasmile Oct 07 167 mph
    Z06 wheels (18X10 & 19X11), Toyo Proxes4 275/295, Bilstein Spts, 4.10 diff & HD shaft, Melrose Hdrs H/F Cats, CHarris ported TB, spacer, Honker, GHL's, Lowrd, Breathless shftr
    MTI Houston INSTALLED and tuned:
    Comp(228/232 113, .588/.575),918springs&hdnd rods UDpulley, 430 rwhp, 404 rwtq Dynojet 248c before
    GulfCoastPerformance Houston INSTALLED
    HD 4.10 gear & dvrs shaft swap R PURP
    Jul 2004
    1,579
    When you order today, you get:
    - OBD-II cable to plug into your diagnostic port
    - USB HPTuner Box (Standard ($499) or Pro($649))
    - 8 credits to use towards licensing any vehicles or Custom OS you want
    - USB Cable for your laptop
    You do not get the serial version anymore, the USB replaced it. You only need one cable to tune all the vehicles HPTuners supports.
    Nov 2007
    Quote Originally Posted by Bill@HPTuners
    So the serial interface version. Can you buy upgrade to it though like 2 bar?
    28,772
    Yes, all of that is done right from your customer login page at www.hptuners.com simply login & click the order upgrades link to start the process.
    Hi there I am a newbie to Hptuners learning the basics. I don't know why everytime I down load a bin file it comes up written in crazy writing I can't read. I thought I might need a certain type of decoder or something but found nothing online please help with this problem!
    28,772
    If you've already loaded hptuners onto your pc it sounds like you need to assign hptuners to be the program that will open .bin & .hpt files.
    Thanks alot I only loaded it to my laptop loading it to my computer now.
    Ok now my computer is saying it could not open the file because it could not find the path.
    28,772
    try saving the file to your desktop, open hptuners, then click file-open & open the file you saved to your desktop.
