Results 1 to 14 of 14
Thread: Cruise engagement with T56 swap in trucks?
    Feb 2006
    22
    I have a 05 chevy truck.
    There are several of us truck guys that have swaped in the T56. More noticably on forums are guys like me that previously had 5 speeds are having problems with cruise not engaging in 6th. I have tried it as slow as 25mph and as fast as 110mph @ 3000 rpms with no luck. I downshift to 5th at the same speeds and it will engage. 4th and 5th will engage cruise at ~25mph.
    I have had no problems getting the proper info in HPT to get the speedo to work correctly with the 17 tooth reluctor wheel vs the 40 tooth that was in it.
    The only plugs going into the trans is the VSS and the reverse light switch. The computer has no way of distinguishing mechanical engagement of 6th gear.
    Any of you guys know about what makes the cruise function tick in the computer and how to correct it?
    Feb 2006
    22
    Ok, let me simplify this a little:
    The trans has no outputs that would allow the computer to differentiate between gears. It will engage in 4th and 5th but not in 6th at any speed or rpm.
    Is there some other criteria input into the computer that must be met to allow cruise to engage such as MAP, VSS pulses, TPS etc?
    Feb 2006
    22
    HELP!
    Aug 2007
    4
    Someone be kind enough to help out on this , as there are several of us that have this problem, ME included .
    Ron
    Dec 2005
    Texas
    254
    has to be something VSS related then, since speed doesnt affect it..
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Probably need the trans segement from a 4.8L manual truck to make things happy but I'm guessing here...
    Always Support Our Troops!
    405
    3,233
    Just a guess, but there is probably some sanity check the computer does with mph/rear gear ratio/rpm to tell the cruise it is OK to engage. When in 6th, you are outside of what the computer thinks is a normal rpm/mph range since the 5 speed didn't have that .5:1 OD ratio. Again, just a guess.
    Aug 2007
    4
    Quote Originally Posted by EC_Tune
    Thanks for the replies . My truck was a 4.8L with 5spd. from the factory. The cruise works in 3rd. and 4th.. I want to get it to work in 5th. and 6th. . The trans is out of an 05 or 06 SSR. I think I need something from an SSR tune or maybe a GTO.
    Thanks Ron
    Aug 2007
    4
    T.T.T. Doesn't anyone know what makes the cruise tick ?
    Feb 2006
    22
    Thanks for the replies guys. I'm kinda with 2xLS1 on the sanity check issue. A couple of times i've actually seen the cruise light flicker when I tried to turn it on in 6th.
    Can someone from HPT tell me if you can create a custom operating system to correct this issue?
    Or what about doing a full re-write with a M6 F body file and starting over with the tune so to speak?
    May 2005
    AZ
    68
    ttt......please help
    2004 C5 Coupe - MM6
    28,774
    Quote Originally Posted by EC_Tune View Post
    Quote Originally Posted by 2001CamaroGuy View Post
    Thats likey your anwser.
    He said in the first post that his truck came with a manual
    Maybe you need a trans segment from a 6 speed car?
    Jun 2020
    3
    I know this is a very old thread but I got it figured out on my truck I did a 2005 cstv segment swap and now it works in all my gears .
