Hi,
Sorry to jump right in as a newby, but as I want to swap a complete LSJ engine into a European Opel Speedster (currently running a Z22SE with E15 pcm) I need to find out a way to disable the VATS/Passlock system in the LSJ's P12 pcm.
I do like to use the standard P12 with HPtuners, as my car also uses a fly-by-wire throttle and that is very difficult to change. And not many (payable) stand alone pcm's support this feature...
Is this possible with HPtuners? I read that this pcm sometimes will ignore the passlock fuel cut-off signal when certain flags are raised. (by a malfunctioning BCM or VATS/Passlock system) So if you can raise these flags with HP...
That would make my life so much easier, otherwise I have to fuse a matching US-BCM + key & lock somewhere into my car.
(I also can use a self-learning remote starter for this purpose, but still need to "program" that with the correct code...)
Thxs
