3800 L32 Table Requests (L67 likely similar)
My OS ID: 12596138
Incorrect Tables: Auto TCC Apply release Tables appear to be incorrectly mapped, they state TPS% by values look to be MPH. This was viewing my stock file.
MAF Low Frequency Threshold (low value in which MAF is disabled; useful to do VE Tune, so you don't have to unplug the MAF)
Knock Retard Recovery Rate (Deg/S) Rate at which PCM recovers from KR; by RPM
Knock Retard Default Value (Deg by A/F Ratio) (We have Maximum)
Supercharger Boost Ramp Rate (rate at which boost is brought in)
Catalyst overtemp boost protection (Cat Temp at which boost solenoid is opened for cooling) I thought this one was in there but couldn't find it.
Any other tables relating to boost control, I had heard the Boost Solenoid in the 04+ is controlled via PCM....I believe this..at part throttle, my boost will *increase* on 1-2 shift when the TPS % doesn't change.
Any tables relating to TQM closing the TB. I do have to test this with TQM Disabled, weather permitting.
