Results 1 to 9 of 9
Thread: Custom 07 Tahoe, Speedometer Issues
    Dec 2007
    Chesterton, IN
    16
    Question Custom 07 Tahoe, Speedometer Issues
    Hey Guys. We are working with a unique project and would like to resolve our speedometer issues. The vehicle is a 2007 Tahoe LTZ SUV with a GM LS7 7.0L engine and GM 4L80E transmission.
    First of all, see our most recent attached tune file...
    We have had the OEM 07 Tahoe PCM & TCM flashed with a new VIN for a vehicle with a 4L80E transmission, for proper operation.
    Our issue is that the speedometer is off because of a gear change size. We attempted to use the automatic calculator by typing in the tire size and gear ratio, but they are not clickable and are shaded out. Why is this happening? Our speedometer is clearly off calibration...
    I appreciate everyone's help... Please advise.
    Scott McKinney
    SMM Performance Parts
    219-241-1099 PHONE
    888-618-2510 FAX
    www.GoSMM.com
    Nov 2005
    Houston, TX
    3,968
    This is a dumb question but if you have another cal open as a compare file and you have the editor viewing the compare file the fields will be greyed out because you can't change the compare file. Are you sure you're not viewing the compare file instead of the main file? What about all the fields under the calculator? Are they greyed out too or just the calc?
    Bill Winters
    Out of the LSx tuning game
    Dec 2007
    Chesterton, IN
    16
    There are no other files opened or being compared, no... We are viewing the main file, yes. Just the calculator fields are grayed out.
    Scott McKinney
    219-241-1099 PHONE
    888-618-2510 FAX
    www.GoSMM.com
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    For some reason the commit button is grayed out. What gear ratio did you install. Would you list the current & stock tire sizes?
    Russ Kemp
    Dec 2007
    Chesterton, IN
    16
    Hi Russ. The gear ratio is 3.73, factory ratio.
    OEM Tires: 275/55/20, 31.8" Diameter
    New Tires: 275/60/20, 33" Diameter
    Scott McKinney
    219-241-1099 PHONE
    888-618-2510 FAX
    www.GoSMM.com
    28,313
    This is because GM has several different ways they calculate gear ratio/tire size in their calibrations, some of which even they fudged some of the numbers to get things to work out right. Our software can only calculate gear ratio/tire size 1 way for a specific calibration which we've tried to calculate the most common one, in the cases where the auto calculate funtion is not available you would need to manually scale the parameters & use the manual scale feature to rescale your shift points & TCC parameters.
    Dec 2005
    Regina, Sask.
    4,214
    This is the best I could come up with. But I don't understand what to do with the VSS Tire Revs per > Dist - Trans field. the help file says this is the tire revs per mile. Yet on some vehicles, this value is the same as the field above it.
    Note that you have to manually scale the shift tables & TCC tables by 1.0377 as shown.
    Russ Kemp
    Apr 2007
    Valley of the Sun
    8
    Quote Originally Posted by Bill@HPTuners
    Bill, On a related subject: Were you guys able to find the 'missing' or 'behind the scenes' parameter for SSRs that is needed to adjust the speedos after a gear change? Maybe it is a combination of parameters?
    ZC
    28,313
    We've added one in the recent weeks & are looking into adding some others that may be needed as well.
