Chris let us know how that file johnh has is set up.
I would be curious to experiment with these switches in the calibration as well.
I thought it was odd that the shop/person that WB tuned my car after the cam install, said out of all of the 3.8l he's tuned my car was the only one that VE tuning made any difference on. Depending on the the information here, perhaps it's not that odd.
http://www.hptuners.com/forum/showthread.php?t=15760
Its in that thread...I'd upload it here, but its on the laptop.
Thanks,
2017 Chevrolet SS, Orange Blast Metallic, Rotofab CAI. Headers coming soon. Stock Tune for now
Previous Rides: 2008 G8 GT, 2004 GTO, 2004 GTP, 2002 TA
John you saved me from going out in the cold.
I remember my car when I added the GenV and Northstar to the already modified platform and I had a heck of a time idling and had very bad transition in the throttle response. Once I did Jerry's recommended VE tune it made all the difference in the world. My switch must be on?
This is my first post here but I have been reading ever since our former vendor left us out to dry![]()
i was under the impresion that the HP tuner guys did a full decompile of the PCM's OS when you first start with a new vehicle.
If this is true, then your engineers could tell you exactly where and how the VE table comes in to play.
But i may be wrong on what i have heard.
I love to hear more about these VE tables tho. And any information on the switching system that enables them. Those two tables mentioned above where SD is an option would be great to have. But also, if it is based on a delta of TPS or MAF delta. Then it would be nice to alter those tables as well.
Good Discussion folks! Keep it going!
Regal GS Site Owner / HPT Moderator / FTV6 Mod
Check to see if your throwing any codes I'd like to test something else.Originally Posted by devildog9999
Nothing popped up Bill.
even when it stalls your not throwing any dtc's that can be scanned with the scanner? For instance I threw a p0101 code the other day & it didn't pop the ses light, but did show in the dtc window in the scanner once I polled for it.Originally Posted by devildog9999
do you guys have any information on weather the VE table is used based on a delta factor of the maf or tps?
Or if you guys really do a true decompile on the pcm
Keeping in mind you can reset the fuel trims automatically with the HP tuner at the click of a button. In which case, you'll see the new trims right away.Originally Posted by JerryH
BTW, do you have a VS cam? I'm contemplating a cam.
2001 Pontiac Firebird Trans Am
1995 Jeep Cherokee
<off topic>
XP FTW! Jerry also has an XP (but I guess I should let himtell you)
</off topic>
It seems different OS's use the VE table different ways. On my 98 GTP I can't tell a big difference, but I can tell a little bit. When I zero'd out the VE table (I know this is a drastic change), the engine had a slight idle surge, other than that I couldn;t tell anything was different but I ony drove the car for about 20 miles this way. Others see a huge difference with a tuned VE table vs stock. My way of thinking is it can't hurt, and if you have a MAF failure your car will run better then if the VE table as stock.
-Eddie
1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - Gen V - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60' (before Gen V or ported heads)
2021 Chevrolet Colorado 2.8 Baby Duramax
Nope, the VS cam is a touch above a stock cam. I have the XP cam (like Eddie mentioned). The XP cam is the most aggressive cam you can use on stock heads, its right at the limit. Anything more aggressive and you need some special head work.Originally Posted by Onyx Dragon
...oh, and the HPT cannot do fuel trim resets on the fly? Thats an extreme time saver... with it you can do up to 10 VE and 10 MAF tunes in a day. WIthout it... MAYBE 1-2 tunes and thats it.. day is over. Time for someone to add that to the request list, its a valuable button for sure!(well we could go back to the old unplug the PCM for 30 minutes thing... but damn!)
'99 Black GTP Sedan
3.4-2.6" PB Quick Change pulleys, Custom CAI, XP Cam, N* TB, LQ4 MAF, SLP headers, 42.5# Injectors, 180/195* thermostat.
13.501 @ 103.392 on 91 (2.4 60-foot).
13.82 @ 105.28 on 87 octane! (2.42 60-foot).
263kph top end as shown on the GPS.
All this and 39MPG to boot. What more can a man ask for?
* Just another enthusiastic amateur tuner! *
See your request thread regarding LTFT reset Jerry.![]()
Who was that masked man!![]()
'99 Black GTP Sedan
It can reset the fuel trims via the VCM controls in the scanner.Originally Posted by JerryH
2010 Camaro SS LS3
SOLO highflow cats|VMax ported TB|Vararam
It has been here for a long time...
Man that's cool!
-Eddie
Yea that's it.Originally Posted by devildog9999
Happy Holidays Gary!
Lee
2010 Camaro SS LS3
