Results 1 to 5 of 5
Thread: New Scan w/ 42.5lbph Injectors - 2.5*kr
    Jan 2008
    43
    Hey, i just installed my 42.5lb injectors into my 02 GTP. I tried to multiply the FlowRate vs. KPA table as i read on here by .87 or so, and it made the car bog out at high rpms. Then i read to multiply by 1.18 or so and it made it knock like crazy, so i went back to the stock setting from DHP and it seems to be fine, only getting 2.5* of KR at 100mph 100%TPS. I posted the scan, any input is appreciated.
    PB... [email protected]'@1.807 no nos.
    Zzp 1.9 rockers,42.5 lucus injectors,poly motor mounts 3.2", custom K/N FWI, Autolite 104s, 180*t-stat, DHP PCM, Pacesetter headers, 3" down pipe, highflow cat, 3'' exhaust to bullet mufflers. Zex dry kit with 75 shot, thrasher throttlebody spacer, Stage 2 dynotech race tranny, 3.29s, 15/16s chain, hardened imput shaft, 3000 pro torque converter.
    Tuner awillis98's Avatar
    Dec 2007
    Port huron
    64
    Just went over your scan. i'm not all to sure but only a couple * knock is not bad. i noticed that your car went a little lean your LTFT should be at 0 and that would get rid of that little bit of knock. i can post a scan so you can see how at 0 there's almost 0* knock
    ..."As I lay rubber down the street,
    I pray for traction I can keep,
    but if I spin and begin to slide,
    I pray dear Lord to protect my ride"! Amen.
    Dec 2007
    Port huron
    64
    Here is that post
    Jan 2008
    43
    Thank you for looking over my scan, Ill take a look at the one you posted, where should i start tuning and how, thanks
    Jan 2007
    New Jersey
    557
    You should mutliply your IFR table by about 1.18. Your running dog rich in PE. Your O2's are over 1000 which is really high. You also need add to your log Air Fuel Ratio Commanded Lo Res and Mass Air Flow Hz. I would also add Trans Current Gear and drop Injector Pulse Width Bank 2 since you don't have a second bank. You need to change your IFR table then work on your MAF table. Your LTFT's are terrible. You don't need to go WOT to work on your MAF table. Just get log data up to about 7500hz. Once you get your LTFT's in a good range, about -5 to +5, then you can work on your WOT fueling.
    2005 Grand Prix GTP
    My CarDomain Page
