just got wideband hooked up through my egr.
my afr fluctuates ALOT. at idle, cruise, everywhere (12-23, 23 is the highest it will read) except WOT. at wot it stays around 10.5-10.8)
its a new setup, just installed the cam and is running off e85.
what could be causing this? i dont think it should fluctuate that much, i know i still have tunning (maf and VE) to do, but the maf tune is in the ballpark right now
side not on afr. im using 14.7 as 1 lambda. so even though it says 10.8 at wot, thats not the true afr with E85, but it is .73 lambda. i do need to lean it a hair.
