I'm working on an '02 Cavalier with the flash from the GM S/C upgrade. Does anyone know what size injectors are in this kit? The factory injector is suppose to be rated 24# at 43.5 psi (I'm not 100% sure this is correct), so obviously the injectors in this kit are larger. However, what's confusing is that the factory GM flash shows the "Injector Constant" as 0.20250, but the upgraded GM 2-bar flash shows the "Injector Constant" as 0.32359. With a larger injector the "Injector Constant" should get smaller. However, in this particular case, I assume that the reason this particular flash has a larger value is potentially from some sort of scaling due to the 2-bar integration GM did???
Thanks for any help in advance.
Regards,
James
