Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: Whats going on..HELP
    Feb 2008
    248
    bill look at this scan....brand new o2 sensor... what else could be the problem?
    The old o2 wasent reading anything...and no ses light...seems like it would have thrown one
    28,312
    02 looks fine in this log.
    Feb 2008
    248
    not at wot...there at 76...74...82...ect...low numbers...i'd be blowing stuff up anything under 600mv
    28,312
    Quote Originally Posted by TDCRacing
    That doesn't mean your NB is off or not functioning.
    What is your wideband verified afr at wot at?
    Feb 2008
    248
    i dont have a wideband
  6. #26
    28,312
    Then that is a problem on a modified vehicle with a blower & a good amount of modifications. I would assume you are lean & very close to hurting something internally.
  7. #27
    Feb 2008
    248
    were you wanting me to find out my pe enable afr?
  8. #28
    28,312
    your commanded afr means very little in the grand scheme of things.
  9. #29
    Feb 2008
    248
    So your saying that nothing is wrong with my nb o2 correct? So what it's readding so lean it's not giving accurate info? What wb WOULD YOU GET ...i trust you and will be ordering that one momentairly...and can i use it with the hpt version that doesent have the inputs for the wb? or will it not be doing me any good unless i upgrade the hpt also?
    Thanks for your time.
    The only question i have really not have answered on here is WHY my nb is showing numbers that low...i have never seen that before on my car at wot
  10. #30
    Oct 2007
    Lawrenceville, Ga
    332
    What size injectors are you running? I would guess your running pretty lean.
    Have you tried adding fuel? What did that do?
    -Eddie
    1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - Gen V - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
    1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60' (before Gen V or ported heads)
    2021 Chevrolet Colorado 2.8 Baby Duramax
  11. #31
    Feb 2008
    248
    Thanks for the reply eddie. I was told that a 3.0 or under would require bigger injectors.I have a 3.2 pulley.Tried adding fuel using what the maf table? yes...I added .3 and i added .6 on 2 different tunes.I didnt pay attention because i really wasent sure if that was the right way to increase fueling. But i figured with the bigger tb that the maf table would need to be increased. I realize that by raising the maf table that it is telling the pcm that more air is being taken in...thus more fuel correct?...is that the proper way to do it? what about the numbers that i used to increase it by?to much to little??
  12. #32
    Feb 2008
    248
    increased the maf table and o2's came back but they were lean...i'm still working on getting it just right but i am verry close...o2's at about 910 right now at most of the rpm range...some of the rpm range im at 860-890.so still a little lean
    So just so everyone knows the reason why my o2's were at 76-86 is because i was running very lean and the nb wasent reading the correct numbers....thats all i wanted to know.And i also wanted toknow how to fix it the best i could for now....so thanks for everyone's help
