What should I put for the Fan on/off settings for a 160 thermostat? I was thinking 165/162 for fan 1 and 180ish for fan 2.
Also, should I enable the climate control override?
Thanks,
Thanks,
98GTP - XP cam, P&P heads, GenV, 2.8/3.4mps, ZZP S3 I/C, dynotech tranny, FWI, TOG Xtreme Headers, 8.5:1 diamond pistons, LS1 TB and MAF, Si Valves, Comp lifters, ZZP base tune, 42#inj, machined intake, oversize rad, 3"exhaust w/no cat or res, Walbro 340,
Not sure what this would be in *F, but when I was running a 160* stat I had Fan 1 set to come on at 79* and turn off at 75*. Fan 2 turned on at 85* and off at 78*.
-Eddie
1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - Gen V - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60' (before Gen V or ported heads)
2021 Chevrolet Colorado 2.8 Baby Duramax
Fan #1 on temp=185*
Fan #1 off temp=174*
Fan #2 on temp=187*
Fan #2 off temp=183*
Keep Climate Control Disable set to "Disabled"
Also set your Ignition Off to 179* and whatever time you are comfortable with(mine is set to 120 sec's)
You might also want to change the enable speeds as well. Mine are now set to:
Fan 1 Enable: 52mph
Fan 1 Disable: 55mph
Fan 2 Enable: 74mph
Fan 2 Disable: 77mph
Will it have trouble keeping temp at 160 with the fans coming on that late?
Haven't had to touch those settings for two years now. Temp stays a lot more constant. With the factory one the coolant temp was all over the place.
Alright, I'll try those settings. Thanks for the help.
What are the settings for a 180 ?
Personally, I'd just subtract the difference between the thermostats, and then lower the on/off settings by that much (180 would be -15; 160 would be -35). Then, I'd just set the key off one at the thermostat temperature rating.
The thermostat isn't fully open at 160; it begins to open at that point. Flipping the fans once it cracks is kind of pointless, in my opinion.
Heres what I'm using with my 180* stat - works good.
-Eddie
thanx! I've just try it, it works perfectly !Originally Posted by Eddie-98GTP
