Results 1 to 3 of 3
Thread: Excel help? Changing cell reference
    2,974
    I've got a weird situation where I need to quickly change a cells reference.
    For instance.. I have three columns
    MAP, RPM, G-Meter
    But in another situation I have
    MAP, RPM, Brake temp, G-Meter, Trans Temp
    What i want to do is have a cell that says go to C1 for G-meter in the case I get the first set of data and D1 for G-meter if I get the second case of data by changing one cell that I'm going to use as a constant. For instance at the top of the page I'll have "data set in column, D" Is this possible?
    Tuner at PCMofnc.com
    Apr 2006
    Twin Cities, MN
    139
    should post your file.
    The '07 Aura XR
    [In] XM ExpressEZ
    [Next] intake res delete, Tint, Eibachs
    The Procharged Ion - SMP Stage 2 QC
    20/5 tint, SPS stb, CF dash, reflective bumper insert, 62mm TB, RL plugs, masked corners, progress rsb, RL fsb, 2.5" cat-back, triple pod w/ Boost, FPG, LC-1 & XD-16, filled front & rear mounts, pclear shorty shift, Procharged, Eibach Pros, 8k HIDs - 188.28whp / 175.03wtq, NO TUNE
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    You have to write a visual basic code to make it do that.
    Sulski Performance Tuning
