check my tune please for sts gt67 ls1 m6 98 trans am
Hey guys I was wondering if anyone had a tune I could use as a base for my turbo install. I am running a cat delete kit from Mac, ls6 intake with racetronix 42lb injectors and 255 fuel pump. I am going to run 8psi boost and 91 octane.
Thanks,Chris.
[email protected]
here is what I have so far and here is a log as well any suggestions?
any tips?
should I adjust the Ifr tables The ltft's are high.
I set up your IFR table for the 42# injectors (to lower the LTFT's) and the open loop table. You need to log commanded AFR & Maf Hz so your AFR error histogram will work. Since the 1998 pcm only supports 24 bytes, you will need to delete unnecessary pids such as Maf g/sec, fuel trim cell, and O2 voltage.
Also set your PE to 11.5, or 12.0 if your intercooled. And install a 160*F stat & lower the fan temps. I would install 2 heat range colder than stock spark plugs.
Russ Kemp
