I'm running 42.5 injectors and having a hard time scaling this thing right. Does anyone have a table for these injectors handy?
Thanks.... John
Thanks.... John
2000 Grand Prix GTP 11.586 @ 118.20
Best MPH: 121.72
New Ride: 04 GTO no times or anything yet
OK. adjusted the stock IFR table, multipied it by 1.19 and its pretty damn close now. A little rich at idle and cruise and a bit lean at WOT. Close enough for now.
Anyone have any tips for fine tuning the IFR table?
Like which ones need to be raised or lowered for the fine tuning....
Best MPH: 121.72
back in the day thread but it's lookin like im gunna need help on this also
2004 GTO LS1~HP Tuners~AFX W/B~PRC 227 heads~.644/.598-231/234-111(TQV3)~Kooks 1 7/8 headers~Stock injectors~Fast 102 LSXR Intake~Fast 102 TB~CAI cold air intake~Yella Terra Roller Rockers~Fast Fuel Rails~
Dyno's are for sissy's, See you on the street.
The proper multiplication factor is 1.18055, not 19%.
'99 Black GTP Sedan
3.4-2.6" PB Quick Change pulleys, Custom CAI, XP Cam, N* TB, LQ4 MAF, SLP headers, 42.5# Injectors, 180/195* thermostat.
13.501 @ 103.392 on 91 (2.4 60-foot).
13.82 @ 105.28 on 87 octane! (2.42 60-foot).
263kph top end as shown on the GPS.
All this and 39MPG to boot. What more can a man ask for?
* Just another enthusiastic amateur tuner! *
Why can't you jut put 42.5 in that table? if the injectors are 42.5 pound hour injectors then why can't you just put 42.5 in all the way across the table?
I don't understand why some cars have some scaling from 36.10 at 0-kpa to 38.40 at 100-kpa and other cars will have 38.16 all the way across on GTP's for example.
Sorry for the hyjack but it seemed like the right time & place to ask.
Best 60' = 1.716
Best ET = 12.186
Best MPH = 112.98
It depends on two things:
A. The pressure that the injectors were rated at and what they will be run at. If they were rated to flow 42.5#/hr at 43.5 PSI (3 bar) of fuel pressure and they will be run at 58 PSI (4 bar) of fuel pressure then they will be flowing more than 42.5 #/hr and the flow increase is not linear, it's exponential.
B. If the fuel system does not change the fuel pressure based on manifold pressure and manifold vacuum (boost and/or vacuum referenced) then the injectors flow more (at idle when manifold vacuum helps to suck the fuel out of the injector) or less (under boost when the fuel has to work against the manifold pressure).
Bill Winters
Out of the LSx tuning game
So your saying 18.055%?Originally Posted by JerryH
100% = 1
Mitchell
'04 Supercharged MC SS
MOD LIST
Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
Hey 5 Liter Eater...
Seeing as someone else brought this topic up, can you answer this?
OEM L36 has the IFR set all the same in all cells.
L67, or at least newer version seem to have this "Ramping" IFR table.
A person with an L36 with boost (Turbo) should run which type of these tables? Ramping because now it's boosted? Still running a 1 bar MAP though.
If the ramping table is better how would you figure out the ramp?
Thanx,
Krunch
2002 Monte Carlo SS "Project Intimidator"
[*DHP PowerTuner*] [L36] [180 TStat] [ZZP HVTB] [HV3] [Resonator & U-Bend Delete] [Carsound Hi Flow Cat] [Corsa Catback] [P&P OEM Manifolds] [Precision PT61] [ZZP Trans] [3000 Stall] [2.93 Gears] [F-Body Calipers] [Water-To-Air IC] [AFCO Ford SVT HE] [IAT Post-IC] [Bosch IC Pump] [9.5L System Fluid Capacity]
If the system is not vacuum/boost referenced (all returnless systems that I am aware of are not referenced) then the IFR table needs to be sloped. If you have a return style system that references vacuum and boost then you should have a flat IFR table because the regulator is accounting for the fueling differences based on manifold vacuum/pressure.
For the ramp rate, search for injector.xls and plug in your numbers and it figures it out for you.![]()
Bill Winters
While I appreciate your answer, I must admit, I don't understand it![]()
I'm not sure which of those two criteria is met on my car. My car has vacumm AND boost, but the MAP only sees from vacumm up to 1 bar, it doesn't see the boost. Some day I might upgrade to a 2 or more bar MAP, but not right now.
Could you clarify your answer better on how it relates to an L67 car with boost that the PCM sees, a NA car which has no boost at all, and my car that has boost, but only a 1 bar MAP.
Thanx,
Krunch
An injector works as an electronically controlled nozzle across a pressure difference. In an engine with a return style fuel system with a fuel pressure regulator with a connection to manifold vacuum/pressure the regulator keeps the pressure drop across the injector constant at whatever the "line off" setting is. This means for an engine under vacuum the fuel pressure drops to compensate for the pull on the engine side of the injector and when an engine goes to possitive pressure the pressure in the rail rises to compensate for the push on the injector. The MAP sensor has nothing to do with the injector tables as best I know (a bit new to the practical world of tuning these cars). When GM, and every other manufacturer for that mater, went to returnless systems for emissions reasons the rail is at a constant pressure and to maintain the same amount of fuel comming out of the injector the table must be skewed to match the change in pressure drop and the equivilent change in fuel flow. In this there would be MAP input but they didn't change that till the L29/32 in 2004.
Central TEXAS Sleeper
Experimental Physicist
Current:
1964 Riviera (4.1L Buick Turbo6, 4L80E, L67 PCM)
2012 Hyundai Genesis Sedan (3.8 GDI, 8spd Aisin)
1998 Chevrolet Suburban K2500 (454, 4L80E)
SOLD:
1970 Riviera
1965 Riviera GS (465 Super Wildcat, SP400) #'s Matching
1967 Skylark Deluxe
1997.5 Regal GS
This is interesting info. I've seen and heard only the 97 L67 PCM's use the flat IFR table, whereas 98 and up switched to sloped IFR tables. My 97 has flat rate and my 99 has sloped. I'ma have to look into thos a bit further now.Originally Posted by 5_Liter_Eater
99GTP: Flowmasters, ZZP Power log & Ported rear, 9.5:1, Bored over .010, removed balance shaft, Dbl roller chain, Intense S1X, custom ported heads, 45#inj., 105lb springs, 1.7 rockers, A103's, 180-stat, Gen V swap, 97 Cadillac TB & Custom machined alum. spacer, 95 GTP Hood louvers
97GTP: Stock engine, 95 GTP Hood louvers
Indeed, you are correct.Originally Posted by louvered97gtp
I switched my 97 over to the sloped table for IFR (amongst other matching changes in other tables) a long time ago.. Been using the sloped table for more then 1.5 years now.
97 Grand Prix GTP (not going to bother listing mods in detail) 1 messed up 97 PCM with about 30-50% of a 2003 calibration and parts of a few others.
Very well said.Originally Posted by CTX-SLPR
Returnless fuel system=sloped IFR
Return fuel system (with a vacuum line attached to the regulator)=flat IFR
Bill Winters
So, is the shorter, less technical answer...
The L67 uses a sloped IFR as it has a returnless fuel system, but the L36 uses the flat IFR because it has a return fuel system?
Now I suspect that just because I added a turbo kit to my car, there were no modifications to the fuel system itself to justify a sloped IFR, but again, I'm running a flat IFR in a car that wasn't boosted, but now is. Fuel demands are way greater now under heavy throttle conditions due to the boost.
I also know that if you made a change in IFR, you could undo that change again with MAF adjustments, so would running a sloped IFR in a boosted L36 produce a smoother looking MAF table?
Is running a sloped IFR table in a boosted L36 good or bad?
Krunch
To be honest I have no idea what the L36 and L67 are. You will need to verify whether each has a returnless or return fuel system. Acutally you just need to know what your car has.
Sure adding a turbo or blower will increase fuel requirements but this should not be accomplished by editing the IFR table. The IFR table defines how much fuel the injectors are flowing at different levels of vacuum (and on a natively FI car this table extends into boost).
So it was elegantly explained by CTX above and I made the very dumbed down version of it above.
So if you know what type of fuel system your car has and what size the injectors are (as well as what pressure they were rated at) then you can determine whether to use flat or sloped and what numbers to use.
Bill Winters
L67 is a return type fuel systsm. L32 is returnless.The L67 uses a sloped IFR as it has a returnless fuel system
Really?? wow... I didn't know that the L32 doesn't have a return.Originally Posted by JFDugal
Ok... knowledge adjustment is now complete... Thanks for the info guys..![]()
Best 60' = 1.716
Best ET = 12.186
Best MPH = 112.98
Sorry but I seem to be a bit thickheaded in trying to figure this out.Originally Posted by 5_Liter_Eater
So i have Siemens 60# injectors rated at 43.5psi
I have a 99GTP with return style fuel system and vacuum on stock FPR
Based on this I should have a flat graph line in my injector table but I don't. What are the consequences of this?
Also, how is the sloped rate properly calculated.
Stock GTP injector 36lbs divided by new injector 60lbs, so 60/36=1.6667
We multiply our current injector by new upgraded scale factor..
36x 1.6667 = 60.012 lbs new IFR linear chart?
Now, If the above is correct, how do we turn this into a sloped table? We don't use the HPT conversion chart do we. It asks for current and new fuel pressure. Most of us change injectors, not fuel pressure so this conversion chart seem useless you raise fuel pressure correct?
Yeah, it's not making sense to me either. I understand what is being said, but the L36 (3800 NA) and L67 (3800 SC) are both return fuel systems, and by that rationale should both have flat IFR. Although in practice, they don't...why not?
And krunchss, this may be a silly question, but if you've got the ability to tune, why are you still running a 1 bar MAP on a boosted engine? You could start with an L67 tune and work it from that, right?
