Results 1 to 7 of 7
Thread: PE fuel enrichment and knock retard
    Apr 2007
    28
    knock retard causing richer commanded AF ratio??
    I'm tuning a '02 Corvette and ran into something new. I noticed during some WOT 'runs' that the commanded a/f would suddendly drop from the 12.5 I had set to arond 11.9, and the reading on my WB reflected this change. I later cooralated this occuring at the same moment of knock retard. I didn't realize that additional fuel enrichment occured during knock retard, and I can not find a way of editing this. Is this an editable parameter with HP tuners??
    Apr 2007
    28
    anybody??
    Nov 2005
    Houston, TX
    3,968
    Are you sure it wasn't COT?
    Bill Winters
    Out of the LSx tuning game
    Advanced Tuner Dragman's Avatar
    Mar 2004
    kentucky
    491
    Quote Originally Posted by 5_Liter_Eater
    Could be as it is a common issue
    Fastest A4 Coupe Bolt On's
    11.33 @ 119.84 mph OLSD Tune
    Tuning done by www.GearsAreUs.com
    Apr 2007
    28
    COT was my first thought also, so I disabled it, and no difference!!
    Any other ideas?
    Nov 2002
    Central Florida
    2,503
    There are some tables that link spark advance and
    AFR commanded, I haven't played with but remember
    seeing them. Wonder if there is a bump happening
    through this linkage.
    If you had an "air surge" that might push open loop
    EQ up and you'd hope spark down, but if it's in a
    range where you never adjusted the advance table
    then maybe the fuel & spark are just not what the
    air charge likes, and fuel alone isn't covering it?
    I have heard anecdotes about overfueling giving
    unexpected KR (or failing to cover timing?). I'd say
    you want to understand the fuel bump first.
    28,312
    Without posting the tune & scanner log its a guessing game which I don't like to play.
