Results 1 to 20 of 26
Thread: Speedo question
    Jan 2007
    New Jersey
    557
    Speedo question
    I posted this on clubgp but no one really answered and it really doesn't have anything to do with tuning but I was wondering if any of you had any ideas. What is happening is when I'm cruising down the highway at like 65, all of the sudden the speedometer drops down to like 8-10-20 mph, then pops back up to 65 or whatever I'm cruising. Sometimes it does this for several seconds. Any ideas what could be causing this? Where does the speedometer get its reading from?
    2005 Grand Prix GTP
    My CarDomain Page
    Banned vette_doc's Avatar
    Dec 2006
    192
    what is make model? without knowing your car how we can help you?
    Jan 2007
    New Jersey
    557
    It's a 2005 Grand Prix and it is in my sig, lol.
    2005 Grand Prix GTP
    My CarDomain Page
    Jan 2007
    Switzerland
    11
    I have excatly the same car, never experienced that on mine.
    But I remember seeing that on rental cars like Chrysler 300 C or Buick LeSabre...
    If you don't see the drop in your HUD or Scanner, then it could come from a connection in the harness of the speedometer.
    Jan 2007
    New Jersey
    557
    Oh no it drops on the hud too. The hud and the speedo. I guess I should just scan it and see if there are any codes. The idiot light is not on.
    2005 Grand Prix GTP
    My CarDomain Page
    Mar 2008
    Waukesha, WI
    101
    Typically the speed sensor is in the transmission. On my 2002 L67 (and probably yours too) it's way on the passenger side, and it hangs out the top of the transmission.
    The speed signal goes from that sensor to the PCM. Then, the HUD and cluster speedo get their signal from the PCM. Make sure your scanner shows the drop, and make sure the connector and wiring is tight and in good condition before replacing the sensor. With a jack, some jack stands and a small socket set it's not too hard to replace.
    Jan 2007
    New Jersey
    557
    Thanks, I had a feeling it was something with the tranny.
    2005 Grand Prix GTP
    My CarDomain Page
    Aug 2005
    Midlothian, VA
    205
    Quote Originally Posted by Perforator
    This happens on my 03 Trailblazer also. Intermittently.
    Mitchell
    '04 Supercharged MC SS
    MOD LIST
    Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
    Tuner CTX-SLPR's Avatar
    Jan 2008
    College Station, TX
    137
    Is there a VSS buffer on these cars? This sounds like the old digital dashes on the Grand National having an intermittantly bad VSS buffer.
    Central TEXAS Sleeper
    Experimental Physicist
    Current:
    1964 Riviera (4.1L Buick Turbo6, 4L80E, L67 PCM)
    2012 Hyundai Genesis Sedan (3.8 GDI, 8spd Aisin)
    1998 Chevrolet Suburban K2500 (454, 4L80E)
    SOLD:
    1970 Riviera
    1965 Riviera GS (465 Super Wildcat, SP400) #'s Matching
    1967 Skylark Deluxe
    1997.5 Regal GS
    Oct 2007
    Lawrenceville, Ga
    332
    Nope, on his the VSS (Vehicle Speed Sensor) signal goes to the PCM, then the IPC (Instrument Panel Cluster) gets the VSS via Class 2 serial data from the PCM.
    Perf - are you seeing this in your scan? The HUD is coltroled by the IPC, so if there is a problem in the IPC then it would be reflected in the HUD.
    -Eddie
    1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - Gen V - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
    1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60' (before Gen V or ported heads)
    2021 Chevrolet Colorado 2.8 Baby Duramax
    Jan 2007
    New Jersey
    557
    I haven't had a chance to scan yet. It's happening on the speedometer and the hud. This morning it was really bad. Doing about 40 and the speed read 0. The tranny is acting kinda wierd too but it's probably because of the speed jumping all over the place. Anybody know the part number for the VSS? I emailed gmpartsdirect and pace parts and nobody replied yet.
    2005 Grand Prix GTP
    My CarDomain Page
    Oct 2007
    Lawrenceville, Ga
    332
    Should be a 213-3241 Declo #
    -Eddie
    Jan 2007
    New Jersey
    557
    So if I scan, besides looking for codes I should be watching the scanned vehicle speed. If the scanned vehicle speed drops like the speedometer then it's probably something with the vss/cabling, if the scanned vehicle speed does not drop it's probably something with the instrument panel, is that correct Eddie?
    2005 Grand Prix GTP
    My CarDomain Page
    Oct 2007
    Lawrenceville, Ga
    332
    Exactly!
    -Eddie
    Jan 2007
    New Jersey
    557
    Ok I'm definitely going to scan tonight when I get home.
    2005 Grand Prix GTP
    My CarDomain Page
    Jan 2007
    New Jersey
    557
    Murphy's law. This morning when it started it happened less than 5 minutes after I left my house. Tonight I went for a 30 minute drive and it didn't happen at all,lol. No tranny codes either.
    2005 Grand Prix GTP
    My CarDomain Page
    Jan 2007
    New Jersey
    557
    Hold the presses. Just checked the scan. There is one frame where it dropped from 58 to 46 and then back to 54. Didn't even notice it on the HUD and it only happened once in the whole scan. I guess I'm going to check the wiring/plug when it cools down.
    2005 Grand Prix GTP
    My CarDomain Page
    Jan 2007
    New Jersey
    557
    The car had been fine all week. Then yesterday on the way to a pool party with my son all of the sudden the speedo read 0 mph even though I was cruising down the highway. It stayed like that all the way there (about 10 minutes of driving) and when I stopped I checked the codes and it threw P0503 which is VSS signal low input or something. Luckily when I left it started working again. I ordered another VSS sensor when I got home.
    2005 Grand Prix GTP
    My CarDomain Page
    Oct 2007
    Lawrenceville, Ga
    332
    Sounds like a good call - good luck!!!
    -Eddie
    Tuner in Training CSC04's Avatar
    Apr 2008
    COLORADO SPRINGS
    27
    I had VERY similar issues with my 2004 GTP. After chasing my tail for a few weeks, scanning and troubleshooting...
    In my case it ended up being the connector on the back of the IPC.
    The connector was like kinda worn out and would make contact and then not and so on..
    HTH
    Shane
    Engine
    2004 GTP, 1.9 Rockers, 3" Catless DP, 3.5 MPS, 180* t-stat, AL104's, FWI, HPT (pro) . LS1M scanner.
