So I have an LM1 and struggling to get a true readout on my scanner. It seems so easy to hook up, all I have is a white, red and shielded wire coming out of the analog harness. I have tried hooking them up in various configurations using pins #1/ input1 and #5/ ground while logging the LM1 preset in the table display and it will stay at around 12.91AFR.
Why would HPTuners provide a predefined PID that does not work with the stock LM1 output? Do I have to go into the LM programmer and setup my analog outputs to get a proper reading? The directions that come with the LM1 are very vague and I am hoping for a little direction. I must be doing something wrong. Any help is appreciated!! Thanks in advance!
