Results 1 to 11 of 11
Thread: MAP P0106 Question=cam?
    Aug 2008
    9
    Long story short.......
    I swapped in a cammed, but stock ( I do have LT's ) LS2 in my 2005 GTO. The motor ran fine in the car it came out of. Other than some start up issues I fixed, I did not adjust the idle rpm, it was set correctly....fyi
    I installed the motor without taking any sensors apart ( I unplugged the engine harness for the swap ) and re-tuned for start up without a problem. It now starts up on first try without any " gas pedal " or excessive cranking.
    BUT
    Now when it warms up, it goes to a high idle ( 1300 rpm ) with SES light [ECM] P0106 MAP Performance ( pending ) ( current ) ( immature )
    I also get a P0300 and P0507, but I think they are directly related to the MAP issue.
    I swapped the MAP with a spare I have, but that wasn't the problem.
    Is there a tune adjustment I need to make to compensate for the lower vacuum of the motor?
    Thanks.....
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Might be in the Engine Diagnostics section. Check that out first. Generally there is a MAP sanity check and you can adjust the stock values (usually 65 & 55 Kpa) to a wider spread because of the camshaft.
    Always Support Our Troops!
    Aug 2008
    9
    Attachment 14522
    startup2.cfg
    Here you go Jared...Thanks
    28,319
    Aug 2008
    9
    Quote Originally Posted by Bill@HPTuners
    Thank you......
    The links IN the above link, Don't work. Where do I go to find the Diagnostic Instructions links?
    Aug 2008
    9
    Ok I did a check as outlined in the link and it says I should have about 5V at the MAP. I have 12V????? WTH?
    Any thoughts?
    Apr 2003
    Almost 2000 feet.
    7,876
    Yeah, you need to trace the MAP wire back to find out why it has 12 V on it.
    Aug 2008
    9
    original....
    Tuner 01WS6's Avatar
    May 2007
    Tyler, TX
    120
    stock tune
    Aug 2008
    9
    verison 7
    Aug 2008
    9
    scan...
