I have a new turbo setup running twin-charged. I'm exceeding the 11500hz limit on my LQ4 MAF, usually around 5500rpms. Each time I hit 5200+ rpms and the MAF hz is above 11500, fuel is pulled and my afr goes to around 14. It is showing a big drop in calculated cylinder air, which leads me to believe that it is no longer using the MAF table to calculate fueling.
The MAF fail is set to 14000hz, and I bumped up all the VE cells in the higher rpm/kpa ranges (set to 90). Neither of these changes made any difference.
So, I am trying to find out just what happens when the MAF limit is exceeded. Does it fail over to VE? What is causing the calculated air to fall so drastically? Does anyone know?
