Page 10 of 18 FirstFirst ... 67891011121314 ... LastLast
Results 181 to 200 of 352
Thread: New A6 Transmission parameters walkthrough
  1. #181
    Dec 2007
    776
    Quote Originally Posted by bluessv View Post
    Well I've gone for a drive and successfully logged the car with the stock tune running and with my tune running. Everything went fine until I tried to save it to my computer. I LOST THEM AND I'M PISSED!
    All I know is that when I drive around with the stock tune the A6 wants to flare and drag out the 2-3 shift all the time. Nearly every 2-3 shift except for when the car is dead cold. In that case, the A6 won't start flaring until about 5 min into the drive and then will continue for ever and a day.
    Alternatively, when I run my tune (with the higher Base Shift Pressure Upshift on the 2-3 change) the A6 basically stops flaring immediately and starts shifting beautifully. Bare in mind though, my flaring issue is not the same is those out there experiencing a one off flare on the first 2-3 shift. Mine is a continual flare on that shift.
    I have attached my tune so you can compare it to your tunes and/or the stock tunes. Just in case you can't read the OS it's "24243170" which I think is different to the ones in USA but I'm not sure
    3170 is the later/current OS. Yes Holden calibrates this locally for the VE's though it originates in the US. Also used in G8. With all due respect to the guys at the Bend, cant imagine they have a lot of A6 expertise as the trans is only used in "one" car. May be wrong.
    If the pressure increase fixes the flare, thats good, but it may be covering up another problem. Surprised they state it's normal. Have you tried other dealers?
  2. #182
    Dec 2007
    776
    Quote Originally Posted by MNR-0 View Post
    Has anyone managed to remove the TQM (spark retard during shift) totally and at WOT in their A6 yet for all 3 upshifts? If so, please post log and explain how...
    Cause i'm stuffed if I can find a way
    Why you want to remove TM?
  3. #183
    May 2004
    AUSTRALIA
    839
    Quote Originally Posted by LSX378 View Post
    In some circumstances I want the fastest shift possible, and pulling timing does slow the car down.
  4. #184
    Dec 2007
    776
    Horses for courses, but generally TM off results in longer shift times. Nice snappy shifts with TM on, longer with it off. Trans is very good at protecting itself from too much torque differential on shifts.
  5. #185
    Under your shift properties, change your shift time to .21 sec in normal and special mode. Then to help a little more, go to Torque management and adjust the 2-3 shift to .5. This should help your shift a bunch. Then go back and change your base shift pressures back to stock to see if the flare comes back.
  6. #186
    Tuner bluessv's Avatar
    Jan 2009
    Sydney, Australia!!
    108
    As I've played around I've found the shift time best at around .25 and the closer I got to .200 I found it to be too harsh but that might be a personal preference. As I'm still learning can you please explain to me what those changes will do; especially changing the Shift Torque Factor on the 2-3 shift??
    Would just like to know the theory behind the changes before I apply them.
    Cheers!!
  7. #187
    Mar 2007
    Llano, TX
    168
    After "spirited" acceleration in 1st and 2nd, there is usually something that appears to be a flare on the 2-3 if you back off slightly before the change.
    What is the OS number in your trans. 24239353?
    The G8 in the US has had at least 7 revisions since intro so the Oz cars probably have too.
    This is exactly how my truck reacts and my TCM OS is identical to what you have posted. I have an '07 GMC Sierra Denali. The flare ups tend to happen most after running through 1st and 2nd quickly and then letting off at the shift to 3rd, but it will also do it randomly.
    I don't have the latest beta so I can't change the same parameters as y'all yet, but would you mind looking at my tune file and see if the tranny settings and see if I'm on the right track?
    I haven't made any changes since the new tables were released last May or June...work has had me really bogged down!
    Thanks for all the time you guys are putting into this tranny! I would love to re-enable TM but still get good quick/firm shifts and no more damned flare ups on the 2-3!
    2019 F-150 3.5 EcoBoost 4x4
  8. #188
    Jan 2009
    Sydney, Australia!!
    108
    I've read on the forum that when you're trying to change the shift pressures you change the main pressure solenoid but also the individual shift solenoid for that specific shift. Keeping that in mind, to increase the pressure on a certain shift do you only need to change the "Base Shift Pressure Upshift" tables located in the Shift Properties section? Or is there a table to change the specific solenoids for a specific shift?
    The question is prompted after reading a post by Bill in which he uses the scenario of increasing the water pressure in a kitchen by turning on the mains pressure tap, but getting a better result by turning on the kitchen sink tap.
    Gee, hope that didn't just lose everyone....
    Any assistance would be greatly appreciated.
    Also, does anyone have an opinion on "Disabling" the Adaptive Pressure on the upshift. I haven't confirmed it yet, but I think I'm getting a better 2-3 shift when it's off and I'm thinking it's because I've taken the guessing game out of it that the TCM would be playing. Any thoughts...
  9. #189
    Jan 2009
    Sydney, Australia!!
    108
    If anyone is out there who has a consistent problem with the A6 flaring on the 2-3 shift, have you considered bumping up the pressures on that shift? Most of the shifts run pressures considerably higher than the 2-3 shift. I have had endless issues with my A6 flaring every 2-3 change with the stock tune.
    I've bumped up the pressures considerably but nothing over the top when compared to the other shifts. The flaring issue has basically disappeared except for one or two flares after about 5 minutes of driving; but only ever on light throttle. After that, it's all good! I've posted my tune so you can get an idea what I'm talking about. Feel free to give feedback about the pressures.
    Also, does anyone know anything about the "Freeze Adapts" Enable/Disable function in the Trans Diagnostics section. It makes referal to freezing pressure adapts if an invalid torque signal is detected. Has anyone played with this or know exactly what it does? It's enabled in the stock tune.
  10. #190
    Tuner carneb's Avatar
    Apr 2006
    Sydney, Australia
    101
    From what I've read the adaptive pressures should learn what pressure is required for the oncoming and offgoing clutch to ensure good shift quality. The trans should detect a flare or tie up during a gear change and adapt the pressures accordingly. Turning this off means it just uses the standard pressures in the calibration and will not adapt if shifts aren't going right.
    The freeze adapts as you have said is for the loss of the torque signal, like when the maf fails. Changing this will only have an affect if you are mafless.
    VE Calais V 6.0L L98 V8 6L80E
  11. #191
    Dec 2007
    776
    Quote Originally Posted by kenny c View Post
    That is probably the PAS Performance stuff if 1 > 2 quick then let off for cruise. This is a difficult scenario.
    Late model A6 Bimmers have this indecision as well under similar circustances.
    For example, rapid acceleration thru 1 and 2, then back off: are you backing off for a corner that you then want to be back on the gas for corner exit in 2nd still with plenty or rpm at the ready, or are you backing of to go into cruise? The TCM doesnt know.
    A calibrators nightmare. Shift to 3rd or hold 2nd and look like a flare?
    With no access to PAS, makes it hard to fine tune. No doubt in general it is tuned for freeway on ramps, so mostly 1 > 2 > 3 etc up to 70-80mph with the gas pedal well down.
  12. #192
    Mar 2007
    Llano, TX
    168
    That pretty much sums it up.
    So, would you be against bumping the pressure for the 2-3 shift like BlueSSV is mentioning?
  13. #193
    Dec 2007
    776
    Pressure clearly makes a difference in certain shift scenarios and BlueSSV is happy with the results, so worth a try.
    It is worth logging commanded gear vs shift time & related torque levels/torque loss to identify whether it is a true flare (loooong shift time), or simply that the shift command is not occuring when expected.
    This will also provide some feedback on how pressure is contributing to behavior: shift times shorter or longer, and how pressure adapt is "adapting" behavior over time.
    While the 2-3 cals show lower pressure than 1-2, 3-4, really the pressure is dictated by clutch volume/area, and the need to operate a clutch to achieve a certain shift profile. So without going into actual clutch volumes/areas, this may be why GM sets the 2-3 differently: and it may be simply a theoretically correct number which is generated by a S/W tool for all we know.
  14. #194
    Apr 2006
    Sydney, Australia
    101
    You should also log turbine speed. If flare occurs you will see the turbine speed increase before it drops to the level of the next ratio. Logging calc. ratio also helps in determining when a shift starts and ends, and what happens during the shift.
  15. #195
    Dec 2007
    776
    Quote Originally Posted by carneb View Post
    Good point!
  16. #196
    Dec 2007
    776
    Took the opportunity to relook at this flare thing yesterday.
    Medium throttle, 200-300Nm, 1 > 2 > 3 nice snappy shifts, 0.2s or less.
    Medium throttle, 200-300Nm, 1 > 2, back off, commanded 2 > 3 change is delayed maybe 1sec. After delay, shift command is given, shift occurs in 0.2-0.3sec.
    Trans clearly waiting to see whether it gets gassed again, or is now in cruise mode. Be nice if there was access to PAS options to fine tune PAS.
    Light throttle, 100Nm, 1 > 2 > 3, shifts normal 0.2 - 0.3 sec.
    FWIW.
  17. #197
    Mar 2007
    Llano, TX
    168
    FWIW.
    Would either of you mind sharing your scanner config? I've set up some configs in the past that just didn't seem to work right. I've been using one that EC Tune put together for gen IV's and it works great, but it doesn't log any transmission parameters.
  18. #198
    Dec 2007
    776
    We log in car with a Dashdaq which sits on the dash and gives a full digital or analog readout, so we dont have to worry about PC's.
    You need to look for GM parameters like:
    Engine Steady State Calculated Torque
    Transmission Commanded Gear
    Transmission Last Shift Time
    or similar naming.
    Sorry dont have time at present to track down the exact ones you need in HPT.
    Dont hesitate to check the help files too!
    Enjoy!
  19. #199
    Mar 2007
    Llano, TX
    168
    or similar naming.
    Enjoy!
    Thanks! I'll play with it tomorrow. I've made my own configs, but I usually either don't add enough data which results in a useless scan file, or I add too much and the scanner hangs up.
  20. #200
    Apr 2006
    Sydney, Australia
    101
    I've attached the config I use.
