I have a stock 2006 GTO with a few bolt-ons and I would like to tune it with HPT. Where do I get the O2 bung welded in so I can use the Wideband? I know its before the cats but there isn't much room between the exhaust manifold and the cats.
2000 Trans Am WS6, 383 RWHP 344 RWTQ
2006 GTO, LS2, Cyclone Gray, M6, 1 of 475
2009 Chevy Silverado
Several options come to mind.
1. The bank 2 pre-cat O2 sensor can actually be reached from inside the engine compartment (facing the car with the hood open it's on the left just below the starter).
You could then temporarily put the WB here and tune the car in open loop.
2. Unbolt the catted mid-pipe on either side (bank 2 side is a little easier to access) and have the bung welded just after the OEM bung.
Flea
2006 GTO
Kooks LTs, NGK WB
12.96 @109.12
Is there a way to tune if I put the Wideband O2 in the tailpipe?
Only if you remove the catalytic converters. But if you do that, you might as well use one of the secondary O2 sensor bungs.
2006 GTO, APS TwinTurbo, Stroked LS3 416ci, LSA heads, LS9 cam, 4L80e
I believe the drivers side bank is the lean bank. I put my wideband on the this bank.
I put mine there too
06 M6 GTO - L92 Heads - Flowtech AK-47 cam - ported LS3 intake - ported TB - Kooks 1 7/8 - Cats - SVEDE OTR CAI - H-Pipe - Flowmaster Super 40s
