Results 21 to 40 of 41
Thread: A6 Shift Times**Could use some help**
    Apr 2005
    Sugar Land, TX
    1,198
    Quote Originally Posted by TonyB4 View Post
    My timing reduction at shift is due from my timing tables. If my car shifts from 6850 in 1st to 5200 in 2nd my commanded timing starts with what I have in that cal.air. I have all TM removed and i am getting NO timing pull during shifts EXCEPT for the differece I have in timing from 6850-5200rpms on the shift.
    I have plenty of logs and the only drop in timing is on the line at launch and thats due to cal.air. For example, if i am stalling my car up to 1750rpms and while holding the pedal my cal.air reading is only say .24 well at .24cal.air my timing is at 33 degrees, well when i stab the gas pedal as the motor winds up its getting more cal.air and scrolling down the timing tables to say .68cal.air, well at cal.air of .68 my timing is setup different and is lower than at cal.air of .24.....Hope this makes sense, if not pm me anytime and i will try and explain better.
    Yes, makes sense. Not sure why you are not getting good solid shifts however with TM disabled. But you have a loose converter and I do not.
    For the launch lower timing you refer. You might try increasing those frames where the timing is lower at launch at the higher cyl. airmass and see if you get a quicker launch. I would think you would be fairly high already with a loose converter.
    On a side note, a looser converter would help you! You have a fairly wide shift extension with that converter. I do realize street and strip is a compromise though.
    Apr 2008
    Buffalo,NY
    64
    Thumbs up
    Quote Originally Posted by 8850 View Post
    Thanks for the advice.
    |466rwhp & 411rwtq|Cartek 3X cam|Vig stall|Bolt ons|Stock 2.56 gears|
    |Stock compression|Cartek dyno tuned| HPTuners pro|
    Cam only
    60ft 1.53 - [email protected]
    60ft 1.56 - [email protected]
    http://s261.photobucket.com/albums/i...onverted-1.flv
    Tuner Joe_G's Avatar
    Oct 2006
    Ft. Lauderdale, FL
    115
    Tony, have you spoken to COW Chuck of Westchester? He is a nice guy in person very helpful and he claims to be very good with the A6. He doesn't frequent this board much.
    2005 Vert Z51 MZ6
    Horsepower Sales 954-984-8040
    4:10's, FAST 92, A/R Headers w/cats, G5x3, .040 gaskets AFR 205 heads ORIG CLUTCH
    472rwhp/414rwtq
    Best pre-cam:1/4-1.730, [email protected]
    Best w-cam, pre-FAST 1/4-1.666, [email protected]
    Best w-cam & FAST 1/4-1.519, [email protected] DA-793
    Best w-cam & AFR heads 1/4-1.445, [email protected] DA-581 1/8-1.445, [email protected] DA-581
    Top speed 185 (so far...) 0-60 mph 2.59 sec (track)
    http://www.youtube.com/watch?v=DUX3UNFl124
    May 2008
    44
    Quote Originally Posted by Joe_G View Post
    He also locks his tunes. Just a heads up
    Apr 2008
    Buffalo,NY
    64
    Joe,
    No i haven`t spoken with Cow. I am waiting to hear back from Howard from Redline to see what he could do first. But thanks for the suggestion.
    Out of all these views no one has any advice???
    Where are the Pro Tuners????
    Cam only
  6. #26
    Apr 2008
    Buffalo,NY
    64
    Question
    Russ K,
    If your out there, do you have any experience with these A6`s?
    Cam only
  7. #27
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,217
    Still working on a 2008 Sierra 2500 HD with the 6L90E. The only changes to firm up the shifts that appear to work, is to reduce the shift times. Note that you can enter up to -32 sec. Start with zero sec shift times & also half the shift torque factor cold modifier table under torque management.
    Russ Kemp
  8. #28
    Feb 2009
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    What about downshift times? Like for merging onto the freeway. It seems to take forever to downshift into the right gear...
  9. #29
    Apr 2008
    Buffalo,NY
    64
    Thumbs up
    Russ Kemp
    Thanks Russ! Is there anyway i can contact you through pm? I have tried but it seems that your pm`s are full.
    Thanks again.
    Cam only
  10. #30
    Apr 2008
    Buffalo,NY
    64
    Cam only
  11. #31
    I set my torque management to 40%. There are plenty of other changes I did but this is the main adjustment. If you still have a problem then there is something specific you'll need to work on for the 1-2 shift. Try this first. If you are past this and still have a problem, I'll try to help you out with my trans file. My G8 will rip second with stock tires at WOT. My be a little different with your 2.56's.
  12. #32
    Here is trans tq factor too. Mine should be stock....
  13. #33
    Apr 2008
    Buffalo,NY
    64
    Thumbs up
    G8-4-speed,
    Thanks for taking the time.
    Cam only
  14. #34
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Tony,
    One other thing that will change the Shift FEEL is the Inertia Factor Profile. Be easy with those as it can really change the feel if you GTF* it.
    Also you might want to change the MAX ADAPT VOLUME on the 2-3 shift to match the others.
    Also, compare with the latest version of the A6 transmission tuning file (2009 Vette) and see what GM decided to alter/improve. None in the repository though...
    *GTF = Gone Too Far
    Always Support Our Troops!
  15. #35
    Apr 2005
    Sugar Land, TX
    1,198
    2009 tune...
  16. #36
    Dec 2007
    776
    2009 tune...
    Good one! Lots of changes in that tune.
    Another very interesting tune would be the CTS-V 6L90E VCM file.
    Anyone out there with one of those?
  17. #37
    Aug 2008
    5
    Has anyone else been able to open the 2009 file above?
  18. #38
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    u need the latest beta to open them up... sent support an email with ur serial #
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
  19. #39
    Aug 2008
    5
    Thanks!!
  20. #40
    Apr 2008
    Buffalo,NY
    64
    Thanks for the help guys.
    Cam only
