Results 1 to 16 of 16
Thread: attn: Russ k 4l80e tune
    Feb 2006
    24
    i was told to contact you once i got my 4l80e installed in my truck. it was a 60e in there for a 2003 1500 of course. ec_tune did the segment swap for me i have the transgo hd2 kit installed. i was just wondering if you could look at my tranny tune and see if anything needs to be firmed up for changed. i am just so scared of breaking it it has been down a while and dont want so soft it burns something up.
    thank you for any help you can give.!!!
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Did you want firmer shifts? Any mods to the engine? Need to know the gear ratio & tire sizes.
    Do you have the stock tune that the 4L80E segment swap came from?
    Russ Kemp
    Feb 2006
    24
    yes the tune i posted is a stock tune file. i compared it with other 80e;s and it is stock.
    right now motor is a 6.0 with just exhaust done. i have just seen where other used pressure to shift with the 80e and 0 out the shift times. just with the stock file i posted shifts are kind of slow and lazy, just didnt want to burn anything up. when i hit the tow haul button shift seems much better. i know that it upped the pressure tables when doing that and shift times were faster. the gear is 3.73 with a stock tire size of 29.20. it shifts pretty good like this now (when in tow haul) but downshifts seem kinda slow when i wot it...but i havent done that much just in case.
    here is a file a forum member sent to me to copy i think we have the same setups with 6.0 and 4l80e. i copied the settings but haven't had time to load it. this also has the stock converter for now.
    so basically yes firmer shifts, times ect.. just want to make sure it is right so i don't break anything with a stock tune that would cause any problems.. if that makes any sense??
    thanks for everyone's help on this!!
    Feb 2006
    24
    sorry no just read again, i do not have the file where the segment came from , EC_TUNE did it for me and he has been very!!! helpful
    Dec 2005
    Regina, Sask.
    4,214
    Do you know what year truck the segment swap was from? Need to know the advertised tire size.
    Are the trans tables the way EC_Tune set up for you?
    Russ Kemp
    Feb 2006
    24
    yes the tables are the stock tables he sent me. it was for a 2003 and the tire size was the same as mine. he said it was stock file and the tire size was the same as my stock tire 29.2 is that what you needed?
    Feb 2006
    24
    just in case due to me not knowing and want to be helpful my stock tire is 265/70/16
    if that helps at all
    Dec 2005
    Regina, Sask.
    4,214
    Try this trans tune. I didn't change the tow/haul part throttle shift speeds, you can play with those if you want. I normally leave them close to stock if you do any towing.
    The speedo should be correct, but check it with a GPS, or pace car.
    Russ Kemp
    Feb 2006
    24
    thanks! but when i try and open the file on both my computers it starts to load...
    then i get "unable to open file. index was outside the bounds of the array."
    any idea why that is?
    Tuner in Training bigwillys58's Avatar
    Nov 2008
    Springfield Tennessee
    20
    Quote Originally Posted by rcmobile View Post
    you need to update your software from your customer login page. he is more than likely running a beta version of hp tuners...
    hope this helps
    08 GMC rcsb 2wd. 4.8/4L80e with a dollar store turbo.
    best so far of 7.25 @ 97.4 1/8 mile
    Feb 2006
    24
    well the version i have is 2.22.3042.17581
    i didnt see anything newer to update in there
    Feb 2006
    24
    any ideas on how to open the file??
    Tuner 01WS6's Avatar
    May 2007
    Tyler, TX
    120
    Yeah, download the new beta for hptuners.
    Feb 2006
    24
    ok thanks i just emailed support to get it. i wasn't sure where too
    Aug 2009
    Calibrating
    3,378
    I know this thread is a little old, but I have a 4L80E tune file for my setup and I have compared against stock and some that are modded, just wondering how it looks/compares.
    Russ I tried to PM/email you, but it said it was blocked?
    Here is my file if you don't mind to take a few minutes
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2009
    Calibrating
    3,378
    oops thought it posted
    14 Gen 5 Viper
