I'm trying to create a sticky for those who have a 64 bit version of vista that are having problems installing the drivers.
Please let me know step by step of what worked for you.
Some of linked to this exe file http://www.ftdichip.com/Drivers/CDM/CDM%202.04.06.exe and it seems to work for most but I would like a step by step of what you needed to do to get it to work correctly so transitiion is as easy as possible ie
1. run exe file found here http://www.ftdichip.com/Drivers/CDM/CDM%202.04.06.exe
2. download drivers found here http://www.hptuners.com/pub/HPT_MPVI_Drivers.zip
3. extract drivers to desktop
4. connect interface to pc
5. install drivers
6. done. at this point everything should work flawlessly
from the sounds of it thats what should happen but seeing I don't have vista 64 I really need to confirm.
Secondly the F8 disable is it just this simple?
1. Turn on pc & hit F8 several times until the advanced boot options menu appears as shown here http://www.hptuners.com/forum/attach...4&d=1190216052
2. select disable driver signature enforcement
3. continue to start pc
4. download drivers found here http://www.hptuners.com/pub/HPT_MPVI_Drivers.zip
5. extract drivers to desktop
6. connect interface to pc
7. install drivers
8. done. at this point everything should work flawlessly
Thanks guys for all your help...this will definitely help alot of people as these 64 bit operating systems become more & more popular.
-Bill
