Results 1 to 5 of 5
Thread: VE Table troubleshooting
    Jun 2006
    Brandon, MS
    17
    Been having some trouble tuning after installing longtubes and a cam. Just a simple question, on the stock operating system with properly tuned injectors should I see any VE Table values above 100? And if there are some above 100 does the computer just ignore them and round it down to 100?
    Michael
    2007 Black Silverado 5.3
    TR220 112lsa, Pacesetter LTs, 44lb Injectors
    28,795
    Over 100 is pretty normal and VE is done on a theoretical % basis to make it a bit easier to understand but those are not the actual numerical values so no the pcm won't round anything down unless you go over the theoretical limit which is 319% or 519% I believe.
    Jun 2006
    Brandon, MS
    17
    ok thanks, it makes more sense now. I was having trouble getting it to reach commanded once it got up the rpms.
    Michael
    Nov 2007
    Minnesota
    555
    Make sure you don't have anything adding or removing fuel
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    Jun 2006
    Brandon, MS
    17
    what should I log that would tell me if it is adjusted the fueling?
    Michael
