greetings. i have a 1999 2wd with an iron 383 and 4l80e trans and it seems to be breaking up in boost and now a bit when not in boost. i'm running a single Borg Warner turbo with the 3BAR flash and all is working well. i'm running TR6 plugs and with 2 separate wide bands they both read 12.5 ish. the truck was working rather well at 8psi so we upped the boost to around 12. it worked o.k. there and then started giving us trouble. i log this every run and see nothing going wrong. the only thing i can think is that i may need more fuel or a timing change. the last coupler tries we stayed around 18 degrees max timing. this was no help. i'm running a C16/93 octane mix and i did a little checking and i've heard a few people talking about "blowing out the spark". could this be the case even at 8psi. i'm just running too good of fuel. i've never heard of such. it doesn't seem like any more or less timing helps... this engine is 9.0:1 compression. oh yes, and i pulled a few plugs and they look absolutely brand new with over 2 hours on the dyno. shouldn't there be some hint of black? any suggestions are very much appreciated! -eli
