Results 1 to 20 of 23
Thread: Reduced Engine Power
    Mar 2009
    28
    Hey guys I got back from the track with new tune and setup. I get reduce engine power when I am in the burn out box. If it doesn't do it in the burn out box then it does it right after launch. I have one code that comes up on the display it is a TCS C1278 . What do you guys think is the problem? Any help much appreciative. I have a C5 Z with a 403 Kenne Bell 2.8 with all the supporting stuff. Tune was done at LMR do you guys think it's tune related? Or is it something else?.
    Feb 2007
    San Antonio, TX
    1,255
    Post copy of log/tune please.
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Jun 2005
    Southern FL
    2,044
    Yeup, as Catalope Kid said, post your tune. My guess is that the P1514/P0068 Error table and possibly the Maximum Delta Airflow - P0101 Error table (if still running MAF) needs adjusting. Until one learns how to adjust it properly, they can just max out the P1514/P0068 table for now, if you haven't already.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
    Mar 2009
    28
    sorry guys I forgot to mention it's a 3 bar tune. The P1514/P0068 is set to 4.10 on all cells.
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    You need to post the tune!! I guess I'll have to do it for you.
    I noticed the ETC scalar is .0355 when it should be .0192 for his 90mm throttle body. Any chance this could cause the problem? Typically when Corvettes go in to reduced power mode, the PCM will disable the EBCM, which will throw the C1278, but there will be the underlying cause code (i.e. 1514 or 1221) that will point to what caused the PCM to send the disable signal to the EBCM. I am being told that there are no other codes. Just the c1278.
    His tune is attached.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    Jan 2008
    242
    Need to set your Maxiumum Delta Airflow-Po101 Error to 255 (not to 0)..Then set DTCs
    PO101-PO102-PO103-to NO MIL Light...
    Mar 2009
    28
    Will that take care of my problem?
    Jan 2008
    242
    Yes
    Jun 2005
    Southern FL
    2,044
    As I thought
    Mar 2009
    28
    Changing the delta airflow didn't do anything. Any other ideas?
    Jan 2008
    Forney, TX
    982
    Load a config to log your dynamic cylinder air and get the car to act up. Let's look at the values in there. If you're exceeding the maximum amount, then you'll have to scale everything back in the IFR/VE.
    Try this histogram.
    http://www.hptuners.com/forum/showpo...7&postcount=12
    and read this while you're at it.
    http://www.hptuners.com/forum/showth...t=12008&page=2
    Also, try to log the pedal position and tps sensor. This problem may have something to do with that or the TAC module since you mentioned the 1516 code. Check all of the grounds with a meter to the PCM as well as absolute ground. Absolute ground is the chassis of the alternator.
    I still don't understand why your ETC scalar value is .0355 for a 90mm throttle body when it should be .0192. It's not right and you might change that, but you'll have to re-tune everything around it to get the car to idle. Call Joe and see if there's any specific reason he did that.
    Mar 2009
    28
    Quote Originally Posted by C5 2000 View Post
    I did this and car wouldn't start. Any other ideas Here is a long file.
    28,303
    anyone notice the iat reading -38*?
    codes should be set to no mil, not mil on second.
    it went to -31, 19 and -6!!!
    and the TPS is stuck at ~20%? sounds like you got some issues bro. how could you miss the IAT? damn thing turns red
    Apr 2009
    Brandon, MS
    What Throttle Body are you running and where is your IAT sensor located?
    Feb 2006
    245
    WOW!!!
    HE PEGGED THAT 3 BAR MAP!
    THAT SURE IS ALOT OF BOOST please provide more details as that sounds
    Feb 2006
    245
    You will have to fudge the VE & IFR to get the g/cyl below 2.32.
    Mar 2009
    28
    After my log on Saturday I found the issue with the IAT. The sensor under the blower in the intake. I put a new sensor in it and it works now. One of my friends is a mechanic and he looked it over. He ended up finding the wiring for the TB had issues. He fixed it and now it works great. I appreciate all you guys help for trying. Thanks
    Mar 2007
    Arkansas
    23
    Problem is still there so can someone tell me how the best way to scale this back for him and will the tune still be close. How much do you scale it back?
    Mar 2007
    Arkansas
    23
    My first question is why the wrong boost reading?
    First pass was a good pass with no issues.
