Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: Supercharger Experts?
    Advanced Tuner n0dih's Avatar
    Mar 2006
    Cherry Valley, IL
    391
    I work in Libertyville, so if you wanna mess with it sometime, we could hook up after work or something.
    Quote Originally Posted by GTPNoga View Post
    Can you tell me where it is in Hex? I am having that same exact problem 4th gear lock up 1900rpm and knocking 1-3* under load.
    Thanks..
    Sep 2007
    Brookfield, IL
    139
    Hmm.... I wonder if I have to keep pulling from my High Octane Spark table.
    2004 GTP: 3.8L SC, XP CAM, 85MM Maf, 105# Springs, 3.3" Pulley, Autolite 103's K&N CAI, 3" Downpipe: TOG Headers, #39 Cobra Injectors, ZZP Crate motor with CNC Ported Heads, NGK AFX Wideband
    Oct 2007
    Lawrenceville, Ga
    332
    No problem, what OSID are you using?
    -Eddie
    1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - Gen V - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
    1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60' (before Gen V or ported heads)
    2021 Chevrolet Colorado 2.8 Baby Duramax
    Sep 2007
    Brookfield, IL
    139
    thats not a bad idea thanks for the offer.
    Sep 2007
    Brookfield, IL
    139
    Eddie it's
    12596136
  6. #26
    Oct 2007
    Lawrenceville, Ga
    332
    Here is a pic for a stock 2004 GTP
    -Eddie
  7. #27
    Sep 2007
    Brookfield, IL
    139
    Thanks!! To me it looks like it's pulling timing up to 1600 rpm and in the upper RPM ranges its not adding nor subtracting. So then I should keep pulling the timing from my High Octane Table.
  8. #28
    Oct 2007
    Lawrenceville, Ga
    332
    Unless you can get them (HPTuner) to add this table, that's pretty much your only option at this point without a raw binary copy of your PCM file.
    -Eddie
  9. #29
    Mar 2006
    Cherry Valley, IL
    391
    If I can hook up to his car, I can make a binary of it.
    Quote Originally Posted by Eddie-98GTP View Post
  10. #30
    Oct 2007
    Lawrenceville, Ga
    332
    Kewl, then I can change it for him if he wants. HPT will read/flash binary files.
    -Eddie
  11. #31
    Mar 2006
    Cherry Valley, IL
    391
    Yup... I also can change that table, I have it. I don't know if my demo of the vdf editor is still good or not, I installed, but never ran it. Might be able to verify if it is the same table or not.
    But can get you a .bin from it easy.
  12. #32
    Oct 2007
    Lawrenceville, Ga
    332
    Oh yea, duh! I guess you can
    -Eddie
